Anyone know of a slim QI charging pad that could be installed that is also magnetic? I have a mophie case and it’s so thick that the phone falls off the ledge into the dash. Was hoping the magnetic portion would fix that.
It’s not magnetic but someone posted this one. https://www.amazon.com/dp/B0793TJ9YR/?coliid=I32T713WMDU9MV&colid=2FG2HG1F1J2GP&psc=0&ref_=lv_ov_lig_dp_it It has a tacky surface that was said to provide some grip. I have never seen a magnetic one.
Thanks. there are tons of magnetic car ones. I just asked the jeda support team and they clarified that their mat does not have this feature.
Whatever you decide on, make sure it is genuinely Qi certified. Amazon has a huge problem with Chinese sellers claiming their product is but it's actually not. The wireless charger rpm Tesla uses are NOT genuine Qi certified and thosw just aren't built to the same level of robustness as the genuine ones. Sure they'll charge your stuff fine, but I bought one and reverse engineered it - they put all the control pcb in the USB dongle and after about 10 min that thing was HOT. Im not putting my 60k car on the line for that crap
Mophie has one thats quite fast and thin. Or you can make your own lol... I actually bought a Samsung one took everything apart and stuck the pieces behind the rubber cover where your phone rests.
The mophe is this ..... http://www.mophie.com/shop/wireless-charging-base?gclid=Cj0KCQjwuYTYBRDsARIsAJnrUXDX7_NUsdF4tOgXI8oV-kjTsI3mA0gonaYxEP5LjuDUn2AhL0YtxboaAhs2EALw_wcB
Wdym? One side is micro usb and the other is regular usb and plus you'd wanna use a usb car charger and connect the wireless charger into that for better speeds
From the website: • Wireless charging base • Wall adapter with 1.5m tethered cable I looked at it and it’s a specialized cable for the pad.
So basically what you're saying is that instead of the other end being usb that you would plug into a car its only a NEMA 5-15 plug? I mean the plug comes with it just like your phone comes with a usb cable and a power adapter and same goes for this wireless charger... I even tried it in the car and it works perfectly
