iPhone X phone call garbled voice
Discussion in 'Model X' started by scsmx, Feb 1, 2018.
Tags:
Is your voice garbled when you are on a call?
  1. Yes
    76.5%
  2. No
    23.5%
  1. scsmx
    scsmx Member
    Washington, DC
    When my iPhone X is connected to my model X and I make or receive a call, my voice sounds garbled. There is a thread on the subject at Apple iphone x & tesla bluetooth issues | Official Apple Support Communities and I was wondering if anyone on the forum is experiencing the same issue. I searched and found no thread on the subject. It looks like the problem is limited to the iPhone X, I have tried the iPhone 7 and had no issues. It would appear this is an Apple issue.
    When the iPhone X was first released there were issues with Bluetooth connectivity, but that seems to have been resolved by either Tesla or Apple updates.
    Thanks,
  2. Lawsteve
    Lawsteve MCATDT
    Tampa, FL
    Here: iPhone X Problem
    Do you use AirPods with your phone? If so, after every time you connect the Airpods and before using the phone in your car you need to turn off Bluetooth on the phone (in settings (not the quick pop-up menu), and disconnect the phone in the car. Then turn on Bluetooth on the phone and recommend in the car. Appears to fix the problem, at least in my case (I am in a Model S, not an X).
  3. scsmx
    scsmx Member
    Washington, DC
    No airpods, I will try your suggestion. thanks.
  4. wang5150
    wang5150 Member
    Phoenix, AZ
    Not sure if it's related, but there was an issue with Apple Watch 3, iPhone X and Bluetooth connectivity that was fixed in a recent update to the Apple Watch. During calls using Model X's speaker/mic, I can hear the caller, but they couldn't hear me.
    After the update, all is working fine for me.
  5. Racerx22b
    Racerx22b @unplggdd on Instagram
    West Palm Beach, FL
    I find that having my phone plugged into the car while using BT causes sound quality issues. If I use BT without being connected via USB I am told I sound better.
    I have no idea if it's just coincidence or a thing.
  6. GEAUXHOOKEM
    GEAUXHOOKEM Member
    Dallas, TX
    I'm around 72 hours into MX ownership and I'm having the same issue. The car itself has been fantastic, but there appear to be some teething issues with regard to the iPhone X and the MX.
  7. golfbern
    golfbern Member
    Sacramento
    The whole phone experience has been extremely annoying. If I am on a call and bring it into the tesla, they can hear me but I can't hear them and have to end the call. Then randomly I get people telling me it sounds like I am a robot. Biggest pain in the ass for me as I am on calls a lot.
  8. NigelM
    NigelM Recovering Member
    Sarasota, FL
    Same issue here with Model S. No problems with iPhone 6 or 7 but my wife and I both just upgraded to the iPhone X and now garbled transmission from the car out (reception in the car is fine). We both have latest FW on phone and watch, still no improvement.
  9. NigelM
    Sarasota, FL
    Thanks for the tip, although that kind of loses the convenience of BT, also this never happened with previous iPhone models.
  10. jeffro01
    jeffro01 Active Member
    SF Bay Area
    Nope, no issues at all with my iPhone X and my Model S... I also have an Apple Watch Series 3 with LTE and also, no problems... I did have to go in an enable contact sync for the Model S in my iPHone's bluetooth settings but that's it...
    Jeff
  11. Lawsteve
    Lawsteve MCATDT
    Tampa, FL
    I agree re inconvenience. I only experience the issue when I use my airpods on my iPhone X. The problem is that I will forget I used them until I am in the car, moving, and answer a call only to hear the caller complaining that they can’t hear me.
    After I do the disconnect sequence I described above (not my idea - a solution mentioned in the thread to which I linked), my iPhone X works fine until I once again use my airpods.
  12. scsmx
    scsmx Member
    Washington, DC
    Turning BT off and on in the car cleared the problem for one call. Works but not user friendly...
  13. PrGrPa
    PrGrPa Member
    Manchester
    I’ve noticed a few Bluetooth connectivity problems with iPhone X with non-Tesla devices. Seems Apple software development might be the main problem. Though I suppose it’s not helped by ageing Bluetooth tech in the S and X.
    I did have iPhone 7 connectivity problems with iOS 11 in my SO’s MB. Those stopped with an iOS update.
  14. Singularity
    Singularity Member
    Los Angeles
    I have the same issue. Calls work fine on speakerphone, but as soon as I switch to the S I sound garbled to them. Also using an iPhone X and a LTE Apple Watch. Will try the suggestions above.
  15. Lawsteve
    Lawsteve MCATDT
    Tampa, FL
    FYI, SW update ver 4.1 does not change this behavior. I still am required to disconnect and reconnect my iPhone X from Bluetooth after every use of my airpods. I too believe this might be an Apple issue.
  16. michael60013
    michael60013 New Member
    Cary, IL
    I have the same exact issue. Took delivery on 12/15.
    I can stream bluetooth from my phone, works great.
    I can head the person on the phone via Bluetooth in Model X, works great.
    They hear my voice as garbled and I sound choppy.
    This is my ONLY complaint since taking delivery. I have to use my iPhone X speaker phone when in the Tesla, which really shouldn't be. I have been in touch with Tesla support and they told me, "sounds like the Mic in your car needs to be replaced". I called the service center and they told me it is a firmware issue with iPhone, doesn't happen with Android and it might be fixed in the future. I would think a $100K car would have working Bluetooth. I have forget and reconnected many times, this doesn't solve it.
    • Disagree x 1
  17. michael60013
    Cary, IL
    I have had this problem, since I picked up my X on 12/15/2017. Someone on the Apple forums on this exact same topic, suggested i put my Apple Watch in airplane mode and guess what, it solved it for me! Give it a try if you are having this problem
  18. Lawsteve
    Lawsteve MCATDT
    Tampa, FL
    When you do the “forget/reconnect” process, you need to make sure you turn off Bluetooth on the phone via the settings icon and not through the pull down control panel . If that doesn't work for you, I once again am useless!!!!
  19. scsmx
    scsmx Member
    Washington, DC
    If I put my Apple Watch in Airplane mode, call quality is excellent. Seems to be associated with the iPhone and 2 active Bluetooth connection which includes the Tesla.
