Definitely eliminate the card as a possibility. You can also try reformatting the card.i installed mine 18 months ago, always worked well. Starting about a month ago it gives three “chirps” after power on and doesn’t seem to be recording. Any hints? Is it possible my sd card needs to be replaced?
Hi all, this is City Racer. The manufacturer recommends that everyone migrate to LuckyCam. This is the app that they will continue to update and support.Just downloaded both apps. They appear to basically be the same app and extremely similar to the original IRO app (no longer in the APP store)
Icons of all 3 for reference.
View attachment 383030 View attachment 383031 View attachment 383032
FYI
CONTINUOUS POWER IN SENTRY MODE! (Standard installation)
I just discovered an interesting side effect of Sentry Mode is the equivalent to continuous power for our IRO dash cam.
I routinely delete all of the “non-driving” videos off the SD card prior to transferring footage to an archival hard drive. Discovered that it records continuously while in Sentry Mode. On a 128g card, there was over 87 gigs of static video, mostly from Sentry Mode.
March 2018 MCU2 Model S 100D
Yep.Are you basically saying that enabling sentry mode keeps the IRO dashcam powered on? Interesting!
Yep.
I’m guessing Sentry Mode will be available on AP2 at some point. Almost certainly with the hardware upgrade for FSD.Yay! But... bummer! This would be the most useful for cars before AP2, when the IRO is the only camera available. But we don't get sentry mode
Sorry, missed the word “before” ... AP2.Yay! But... bummer! This would be the most useful for cars before AP2, when the IRO is the only camera available. But we don't get sentry mode
Daniel, yes the problem was the card. No card, that is. Tesla removed the SD when they did my last service and forgot to put it back in. Ah well, I bought a new one and its working again.Definitely eliminate the card as a possibility. You can also try reformatting the card.
Plus contact the seller on eBay for help.
Interesting, did they confirm that they removed it or are you just assuming so. The reason I’m asking is they’ve never removed my card. Only covered up the lens with blue tape.Daniel, yes the problem was the card. No card, that is. Tesla removed the SD when they did my last service and forgot to put it back in. Ah well, I bought a new one and its working again.
FYI, you can connect a laptop and go to http://192.168.1.254 and download the files without the app.
I was happy to find links to the user manuals in PDF format in the City Racer Website.
Well, the card was in the IRO when I took it in (never even thought to remove it, should have) and ever since I get 5 or 6beeps on start from the dash cam. That was never normal but I didn't figure it out until I tried to format the card per suggestions here. OOPS! No card inserted.Interesting, did they confirm that they removed it or are you just assuming so. The reason I’m asking is they’ve never removed my card. Only covered up the lens with blue tape.
Although that would not prevent it from recording the audio in the car. I always remove the card when I take it in.
