Is a 30' 14-50 extension cord really long enough?
landover
89
0
Pleasant Prairie, WI
I am thinking about just making a 50' one out of 6-2 coper wire just to be on the safe side. I know the 6-2 wire will not be bradded wire like the 30' extension cord but the little use it will get I think it will last for a vary long time without incident.
- - - Updated - - -
This was supposed to be in battery and charging. If a mod could move that would be great. Thanks
FlasherZ
Sig Model S + Sig Model X + Model 3 Resv
Jun 21, 2012
7,024
1,013
NM-B cable (Romex) is *very* stiff at AWG 6... I wouldn't use it for an extension, mainly because of the stiffness of the cable and because over time, bending it back and forth can weaken the thicker strands.
My preference is that 6/4 is used and that neutrals are properly wired, or you use 6/3 and make a 14-50P to 6-50R extension, and use the 6-50 adapter with the UMC. This is because of the danger of using that cord with an RV if someone else grabs it. If you insist, use 6/3 cable with 14-50 to 14-50, but label the cable well with "Tesla charging ONLY! Do not use on RV!".
landover
89
0
Thanks for the reply FlasherZ. I wonder if I can find stranded 6/3 anywhere. I have a friend that works at a wire company in Chicago, Ill ask her if she can get some. My main concern is not having a long enough cord to charge at 40amp. Like going to a cabin for the week/weekend and not being able to make it to the panel or to the stove plug.
linkster
1,128
267
USAX2
Might you consider a Hobart p/n 77064 14-50P to 6-50R adapter along with either a Coleman p/n 1917 8/3 6-50 STW or a CyberWeld 25 or 50' 8/3? This combo has all factory machine assembled molded ends with a nice durable STW jacket and is smaller than the bulky 6/3 or 6/4 at the small expense of pulling a few less amps.
FlasherZ
Jun 21, 2012
7,024
1,013
At 0-50 feet, 8 AWG is only rated for 40A (UL standards for STO, STOW, and SOOW cable). Not a good idea to put 50A plugs and receptacles on it without some type of over-current protection built in. There's a big difference between a welder, typically operating at less than 10% duty cycle, and a continuous load that will be offered by the Tesla. (There is an exception, where a welder is used to power a Xenon lamphouse for a film projector, but that's one of my frankenstein projects. :) )
Keep in mind that while the Tesla will memorize your charging current at a given location, it isn't fool-proof. Over the past 16 months, my garage has been detected as 3 different GPS addresses, and each time it detected a new one, Model S defaulted to the maximum current supplied from the pilot current. Also, during one of the v4.x updates, the charging current reset to the maximum as well.
As a result, you're better off carrying the AWG 6 cord, IMO.
hcsharp
3,373
1,339
Vermont
mitch672
1,861
13
Stoughton, MA
If you can find it, you'd be better off with SEOOW cable (note the 'E'). It's rated for more amps and has the same temperature rating as EVE cable which is made specifically for EV charging applications (105C).
it's on eBay, it's very expensive, here is a 100 foot length of 6/4 SEOOW cable, $355
I don't think it's worth the additional money, but that's each persons decision
100 Seoow 6 4 600V Indoor Outdoor Portable Power Cable | eBay
Here is 100 feet of 6/3 SEOOW for $315
100 Seoow 6 3 600V Indoor Outdoor Portable Power Cable | eBay
landover
89
0
I did get ahold of my friend that works at the wire company. She can sell the 6/3 to me for 3.01 per foot. A little less then ebay. If anyone needs any of this let me know and I will see what shipping would be.
hcsharp
3,373
1,339
Vermont
You can buy 6/3 SEOOW for $2.65/ft here.
And 6/4 (better so you can safely use it for other 14-50 applications) is only 3.25/ft.
TonyWilliams
1,438
758
San Diego - Tesla powered Rav4 EV
Here's another option for 40 amp charging. This cable is the same stuff used in the UMC, however it has more control wires.
If you're making a "dumb" extension cord, you don't care about the control wires.
This does not meet any codes, just like the Tesla UMC (you have to double up parallel conductors):
Quick Charge Power
wcalvin
310
16
Seattle WA USA
You know, it depends on whether this is a temporary travel solution or an in-place extension cord for your usual overnight charging. If the latter, go for the suggested thick-wire solutions.
But if it is for visiting relatives occasionally and tapping into their laundry room, consider the following. The general considerations concerning extension cords are heat loss and safety, if we ignore the absolutism of Tesla's lawyers. The hazard is from a junction that overheats, not from long wire overheating. You can get by on thinner wire if the series voltage drop (=IR) does not take you below the cutoff (don't know the 220 specs but for ordinary outlets 105 volts is the bottom, below which the charger may disconnect during the night).
Yes, you charge a little slower and you do waste some energy via heat loss. If this is a temporary situation, you may be able to rationalize this.
But the strong cautions about using extension cords are mostly misplaced for temporary situations. The heat hazard is from junctions, not length, and is mostly from overused outlets with insecure connections that spark and scar. For dryer outlets, that problem is unlikely; for RV parks, beware.
jerry33
Mar 8, 2012
19,560
21,910
Texas
You wouldn't normally need an extension cord at an RV park because the oulets are right by your parking space--at least they have been in all the RV parks I've been to. RV parks sometimes have poor power but typically the UMC will turn red in a very short time (15 minutes or less). You then move to another space.
landover
89
0
My main reason for the longer cord is when I'm staying at a cabin and the parking is about 50' away form the 220 stove outlet, Or visiting relatives. I already have my house wired with 6/4 nema 14-50 in my garage.
Thanks for the info guys.
FlasherZ
Jun 21, 2012
7,024
1,013
I disagree, and your host's homeowners' insurance is likely to disagree as well. While you are right in that more problems come from junctions, heat is a big concern when you're talking about hours of continuous load charging. Just because it works, doesn't mean it's safe.
landover
89
0
FYI, found that Amazon Prime has 6-3 SEOOW, which is the 105 degree C insulation (better for EV charging), they have 25' lengths in stock for $80 (free 2 day shipping)
Amazon.com: Coleman Cable 096030008 SEOOW SEOPRENE, 6/3, 25-Foot: Home Improvement
Thanks mitch, I ended up getting the 6-3 SEOOW from my friend that works at Electro-Wire for 2.81 a foot for 60'. I sure hope this will be long enough. Ill let you guys know how it goes in about a month or so. Thanks for all the help from everyone here.
ElSupreme
Model S 03182
Jan 13, 2012
4,303
89
Atlanta, GA
I want to bring this up again. I would buy a 3 prong connector (6-50, or 10-30) to use with 3 connector cable. It makes it much safer, and harder to misuse.
I have a female NEMA 10-30 on my 6/3 SOOW cable. and a male 30A twist lock (I forget the number designation) on the other end. I then have two 'adapter' pig tails with large labels on them. One that goes to 14-50, and one that goes to 10-30.
Having a straight extension cord with the 'same' style pug on both ends is a lot easier to use improperly than obvious pig tail adapters. But making sure people can't plug into your cord with both neutral and ground is a very good idea, that is worth more than the $45 6-50 adapter you would need.
