Is excessive heated seat use good for guys "children"?
Discussion in 'Model 3' started by Big1matt, Jan 1, 2017.
Tags:
  1. Big1matt
    Big1matt Member
    Pa
    With electric cars (and ICE cars) using and depending on heated seats more, are these safe to use on a regular basis for a males prospective children? When I get my Model 3, I will surely be expecting to use the heated seat function plenty, and to allow me to use less heat at times during the winter months.
  2. Yggdrasill
    Yggdrasill Active Member
    Kongsberg, Norway
    Yes.
    What is it that you find worrying?
  3. fallen888
    fallen888 Member.. hehe, I said "member"
    Philly(ish), PA
    There's probably more heat between the thighs, which actually has more (and direct) contact with the sack than the heated seat itself. I'm no doctor, but i think you're safe. ;)
  4. JeffK
    JeffK Well-Known Member
    Indianapolis
    Males have other things to worry about when they are concerned about fertility. Low alcohol consumption, stay in the normal weight range, make sure to do moderate exercise, vitamin C and zinc intake, etc.
    If you do have any heat related problems (even from having a fever), rest assured that all the numbers will return to normal in about 3 months.
  5. garsh
    garsh Re Member
    Pittsburgh
    JeffK has it right. The worst thing that you'll be doing is temporarily lowering your sperm count, and there are plenty of other things that will do that as well. And it is just a temporary change - if you're actually trying to have children and are having fertility problems, only then would I start worrying about making lifestyle changes to fix the problem. You're not going to cause any sort of permanent issue by using heated seats.
  6. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Safeguard Your Sperm
    Quote: "After an hour in the hot seat, participants' scrotal temperatures rose to an average of 37.3 °C, with a maximum temperature in one man of 39.7 °C. It’s only a slight increase, but it may be enough to damage the sperm production process, according to Andreas Jung, a researcher at the University of Giessen in Germany.n A third of a degree doesn't sound like much, so we asked for a second opinion from Larry I. Lipshultz, M.D., chief of the division of male reproductive medicine and a professor of urology at Baylor College of Medicine. “Studies have shown that applied heat—like the heat from hot tubs or direct contact with heating pads—really can impair [sperm production],” Lipshultz says. “But research looking at the effects of tight underwear and indirect heat has been very iffy."
    • Informative x 2
  7. S3XY
    S3XY Active Member
    Buffalo, NY
    Pretty simple solution for anyone concerned about this.
    • Funny x 13
  8. JeffK
    Indianapolis
    Yes, it's pretty temperature sensitive... but heat damage is temporary.
    If you're really trying to conceive in the dead of winter then just make sure you moderate your use. Or heck even S3XY's solution would be fine and crank the heat all the up.
    The only people that should really worry are those who are actively trying to conceive, otherwise it's not going to affect anything else such as testosterone production etc.
    There are limits or course, some cars have seat warmers that get hot enough to actually cause burns. Use your best judgement, the max you want to go for is a few degrees below body temp of 98.6 degrees F.
    That said:
    Infrared Camera Shows Tesla Cold Weather Heating Elements
    shows the seats hitting 75-78 degrees on max which is perfectly fine for any length of time as it's well below 95-96 degrees F.
  9. McRat
    McRat Well-Known Member
    LA
    "Did you bring condoms?"
    "No, I'm safe. My car has heated seats..."
    • Funny x 12
  10. BluestarE3
    BluestarE3 Active Member
    Norcal
    • Funny x 3
  11. Dan Detweiler
    Dan Detweiler Member
    Canton, Georgia
    ...but what do I do for an erection lasting more than 4 hours?
    • Funny x 4
  12. JeffK
    Indianapolis
    Turn off ludicrous mode for a while.
    • Funny x 18
  13. AudubonB
    AudubonB Mild-mannered Moderator Lord Vetinari*
    I'm still trying to figure out why, per JeffK post #4, I should worry about low alcohol consumption. I know how to avoid that worry!
  14. JeffK
    Indianapolis
    haha I meant try to have lower alcohol consumption.
    Although higher alcohol consumption can sometimes lead to greater genetic diversity of your offspring... your wife might divorce you though...
    • Funny x 3
  15. Mkorpal
    Mkorpal Member
    Denver
    This car can not get to production fast enough.
    • Funny x 2
  16. BluestarE3
    Norcal
    I can't believe some people aren't treating this subject seriously and offering constructive advice to the OP. :rolleyes:
    In addition to my previous suggestion, here's something else that may help allay concerns:
    Maximize Fertility, Relieve Scrotal Pain
    • Funny x 3
  17. ⚡️ELECTROMAN⚡️
    ⚡️ELECTROMAN⚡️ Fritterer and waster of hours in an off hand wayer
    Portland, Oregon
    #17 ⚡️ELECTROMAN⚡️, Jan 1, 2017
    It could be possible that the OP is worried about EMFs mutating his unborn children. The seats use DC for heating and don't have the fluctuating magnetic fields suspected of causing genetic mutation. The motors, on the other hand, use AC. Maybe he should avoid the AWD Teslas during his reproductive years, just to play it safe?
    • Funny x 2
  18. Jayc
    Jayc Member
    UK
    I think it is a valid concern that the OP has. If someone has any other direct, specific, info or links to specific research findings on the subject, that might help.
  19. patrick42h
    patrick42h Member
    Indianapolis
    I wasn't aware that heated seats were one of our more widely available contraceptive options.
    • Funny x 2
  20. McRat
    LA
    Agreed.
    To the OP, if you are trying to conceive, please turn off the heater during intercourse. You will find this on page 201 of the Owner's Manual under Child Seat Information.
    • Funny x 2
    • Disagree x 1
