when the speed is slow , I can get the noise if i accelerate and deaccelerate . Here is the video.
is it normal? did you roadster have it?
or anyway to fix it?
I may be experiencing the same noise. It's a delayed clunk, maybe 1/2 second after accelerating or decelerating. Sounds a little like a relay.
I heard for the first time a few days ago however today I couldn't hear it at all.
Hey Jason, I think you saying it's a normal sound? Should I check the bolt you have a picture of?
Carl mentioned? Is there
bigger writeup on this?
Thank you.
from 2011 new car - new owner #1425
Clunk noise from behind when accelerating/deaccelerating
now that I see you moving the wheels back and forth on the lift it's definitely the gears inside the motor hitting back and forth; I have the same issue.
It's really not an issue but at the same time it's really not normal for a transmission or motor to do that; but considering other users experience the same issues you should be fine. Just put a little Dynamat on the metal piece I showed you above it will dampen the sound a lot once the belly panel is put back on and re-assembled.
If you drive your car and accelerate and your car shifts to one side and when you slow down regen and it shifts to the other side then you have ripped, jigged, or cracked gears whatever the term is in your motor. If you don't experience this issue your motor is fine.
probably, they have the same type cv drive?Um, this is the Roadster forum... Do these specifics apply?
