sleepydoc
Thank you for the source. I'll have to read the entire article more carefully, but of note, shortly after the graph in question was presented they presented the following graph that compares battery degradation that appears to show significantly higher degradation with higher charges. Even this chart doesn't explicitly state what a 'cycle' is. Classically, it is defined as a full charge -discharge cycle (i.e. 0-100%-0%) but this chart appears to compare a 50% subtotal discharge cycle vs a 60% and 75% discharge cycle. If this is the case the 100-25% curve represents 50% more energy use than the 75-25% curve. Even taking that into account you see more than twice the degradation with the 100-25% cycle.This is the source, near as I can tell.
The article also explicitly says that real world results are always worse than laboratory tests.
Fundamentally, the consistent message for maximizing battery life from the sources I've seen is:
- Avoid charging extremes.
- Avoid rapid discharging and rapid charging.
- Avoid temperature extremes
- Don't let the battery sit completely charged or completely discharged.
