  • The latest TMC Podcast (#14) is now available on YouTube and all major podcast networks. We covered FSD Beta's exciting v11 update, Enhanced Autopilot coming to the U.S. and Canada, and more!
Is it possible to customize the door trims?
I have a model y with white interior trims locked in at $54,990 price. I recently had a change of heart and wanted to switch to black, but customer service told me that changing my interior trims would push my deliver back AND update my price to the current pricing. With that in mind, does anyone know if it's possible to customize the interior parts of door panels that are white? I would love to try and customize them back to black.
jmaddr
1,167
1,161
Florida
The new interior white parts are less than they were. Search Amazon or any Tesla accessory store and you will see carbon fiber, matte, Slavs tea, and everything in between options for covering the white on the dash and white on the doors. They are usually simple stick over options, with options to actually take out the part and replace with a new one more expensive.
Do you happen to have any recommendations that you might know of? Or even what this part of the door is trim is called? I was doing a search last night for it, but I don't think I was searching for the correct key words as I was only getting the slimmer parts such as the dashboard or trims for the interior door handle. I only found options for parts of the door trim, but not the actual bigger white chunks seen below.
I'd check here for the seats if you don't mind actual leather:
You could try the SC for part numbers on door inserts and any other interior pieces that can be obtained in black.
jmaddr
1,167
1,161
Florida
Looks like I made a mistake. I’d edit my post if possible. I thought the Y had the same door trims as the 3. Your picture with the red outline clearly shows the older style door with a leather insert instead of the new design where the dash trim flows into the door.
I don’t know if there is an option to swap those.
RoBoRaT
Zero Farts Given!
Nov 22, 2018
1,780
1,742
NorthSoCal
Did you ask Tesla Parts (local service center) to see if they can order the parts for you?
