Is it possible to recolor wheels?
Discussion in 'Model S: Interior & Exterior' started by NewCow, Feb 3, 2016.
  1. NewCow
    NewCow Member
    Aurora, CO
    I'm new to aftermarket wheels and stuff, but is it possible to change the color of wheels? I personally like the base 19" wheels but would like them in a darker grey/black, but don't know if that's even possible.
  2. CLLACAB
    CLLACAB Member
    Las Vegas, NV
    If you go to YouTube and do a search on wheel refinishing, you will find some great videos - if you are handy. If not, any wheel refinishing shop can paint or powder coat them.
  3. ddimit
    ddimit Member
    Sacramento, California, United States
  4. NewCow
    NewCow Member
    Aurora, CO
    That looks awesome! That's exactly what I'm looking for. Now I know what to search for. Thanks!
  5. GuyGadois
    GuyGadois Member
    SLO
    This is great. What did that set you back and how long did it take them? I am assuming they take off the wheels and keep the car lifted through the process?
  6. ddimit
    ddimit Member
    They had the car for about a day and a half. Yes they lift it and use jack stands. I had quite a conversation with the shop owner to verify they knew what they were doing. I have been very happy with the results. It ran around 150.00 a wheel.
    The Red T Sticker and Brake Calipers I did myself.
    I was looking at the Telsa wheels when ordering and really had a hard time justifying the cost for the result. Way more happy with this outcome, even when they are dirty the look good!
  7. FlatSix911
    FlatSix911 Porsche 918 Hybrid
    Silicon Valley
  8. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    Plasti dip. $6/wheel. and you can pull it off at trade in, and it protects the wheel under it.
    I've gotten pretty good at it now. I might do my other car some funky color just for fun this summer.
  9. Jool
    Jool Member
    San Diego, CA
    Plastidip works great, as other people here have mentioned!
  10. FlatSix911
    Silicon Valley
    Here is another color option with the OEM 19" wheel ... mask of the spokes and rim. :cool:
  11. mspohr
    mspohr Well-Known Member
  12. FlatSix911
    Silicon Valley
    I did my wheels in Graphite Pearl ... Forged BMW M6 wheels at less than 25 lbs. per corner.
  13. Stiff1
    Stiff1 Member
    Chicago, IL
    I ended up powder coating my winter wheels bronze. With powder you can pick just about any color you like and keep your car unique.
  14. TaoJones
    TaoJones Beyond Driven
    The Americas
    Had mine powdercoated to match the steel grey paint - I didn't want to have to deal with light-colored rims, and there's enough silver-colored plastic trim on the car already.
    Verne's Chrome Plating in Gardena (Los Angeles area - ask for Bob Barnes) did a fantastic job, as did the Torrance SvC in loaning me a set of wheels that they just happened to have handy. They charged $125 to remount, balance, and deal with the TPMS parts and pieces. No complaints.
    Verne's also found a wayward chunk of metal that had been embedded in one of my rims during the manufacturing process. That was a little troubling. They also determined that the stock rims have already been coated three times - primer, that silver color, and clear.
  15. Spyder14
    Spyder14 Member
    Bluffton, SC
    For a permanent, high-quality re-finish, powder coating is certainly the way to go. But you can't go back or "change your mind"! I used Plasti-Dip on my 911S wheels for protection but really liked the slight color change (OEM silver to Aluminum + Metallizer + Dip Coat). The biggest issue for me was cleaning off the brake dust since the finish does not lend itself to aggressive rubbing or scrubbing. BDP Wheel Cleaner is a big help but power washing took care of most of the cleaning. Any dings or scrapes can be fixed using the Plasti-Dip repair kit (special type of solvent). From 5 feet away they look great--you stick your nose into it & you can see some small imperfections but it was DIY!
  16. Xenoilphobe
    Xenoilphobe Active Member
    Fairfax County, Virginia
    #16 Xenoilphobe, Feb 8, 2016
  17. TT76
    TT76 Member
    Switzerland
    Hi Jool
    Is that your MS? What plasti dip color did you use here? They look awesome! I want mine exactly the same way! Luv them!
  18. anxman
    anxman Member
    san francisco, ca
    Had my wheels powder coated. Also been pretty happy with it. I would recommend going matte black (versus gloss black). When you inevitably end up with some wheel rash, just take a black sharpie marker and color it in. It's a cheap and effective solution.
  19. shokunin
    shokunin P85 & M3
    Irvine, CA
    Those with Plastidip, do you have to redo the dip when you get new tires or balancing? I know those tire machines can be brutal and can scratch even the paint/clear coat on the rims. Do they rip with you install the lug nuts on them?
  20. ssq
    ssq Member
    Beautiful! Did you plastidip them yourself? Also, where did you buy the plastidip from?
    Care to share some more pictures?
