I put my credit card on the sliding centre console and I assume it slipped down the back.
Worth pulling it apart or just order a new card?
The bottom of the cubby hole above the center console easily pops down which gives you good access to reach behind the the sliding door of the lower console with the lid in the closed position.
I lost a check in that same spot awhile ago and called my service center who told me it was really easy to do.
Although I haven't lost anything there yet, can someone post a video? TIA
Came across this thread when I had this exact issue - replying with some pictures so it can help the next person. I had previously lost a check that slid down and back behind. I tried everything from rulers, to vaccum cleaners to try to get it out. Until I found this thread:
Press down on the tray below the nav screen, there is a tab both left and right. It will take some force. I did one side at a time.
View attachment 267007View attachment 267006
Then slide the tray out towards you.
You can then see thru to the back and reach to get your paper, CC, etc that has fallen behind.
Putting it back is simple, there are back tabs on the tray to insert easily into backside, then pop the tray back up into position on the left and right clips.
Ill try and do one, basically all your do is put your fingers in the cubby below the screen and push down firmly. The tray just pops out and you have access to the area where the top of the centre console slides.
