father_of_6
Membler
That's definitely possible, but it ran for quite a while (and if so it definitely failed, LOL)OR: the car was actively drying the evaporator of your AC, to try to (and fail at) prevent bad odors.
It's easier on the onboard AC charger. It maxes out at 48 amps and you're running it full tilt.I've seen no evidence that charging at 30 amps vs 40 (I charge at 48) is better for the battery. 40 amps is only 9.6kW, 48 is 11.5kW. Even at 48 amps, that's less than 1/6c. Peak supercharger power is 250kW, over 3c. 3c is pretty rough on a battery, 1/6c is not.
I just leave my HPWC at 48 amps, plug in every day, and set my departure to 6:00 so my higher SoC is held for a shorter time.
I’m flattered you’ve taken the time.I've seen your posting history and you're a Troll.
Is there any evidence that the onboard chargers are failing at a higher rate when charging at 48 amps? (I'm not trying to be argumentative; I like data to drive decisions.)It's easier on the onboard AC charger. It maxes out at 48 amps and you're running it full tilt.
I haven't seen anything on that anywhere. I also would imagine that there would be something about that in the Owner's Manual. It's pretty detailed regarding recommendations about battery care, and if this was really something to be concerned about, then you'd think they would have called it out as a recommendation. Or even limit charging to less than 48 amps via SW update.Is there any evidence that the onboard chargers are failing at a higher rate when charging at 48 amps? (I'm not trying to be argumentative; I like data to drive decisions.)
i think theres data out there that charging at 48A is less efficient on your home wiring.. i^2 * t and all (also dependent on your feeder size).. if youre not worried about the minor difference in the cost of electricity though it probably doesnt matterIs there any evidence that the onboard chargers are failing at a higher rate when charging at 48 amps? (I'm not trying to be argumentative; I like data to drive decisions.)
I’d question whether any losses from increased resistance would be enough to overcome the 250-300w overhead of powering the car and charging circuitry over the longer period necessary to charge more slowly.i think theres data out there that charging at 48A is less efficient on your home wiring.. i^2 * t and all (also dependent on your feeder size).. if youre not worried about the minor difference in the cost of electricity though it probably doesnt matter
I was wondering if I could plug it in and setting charge limit to 50% (even if there is 75% charge on the batteries).
If you want to plug in each night but not charge when the battery is already at a decent state of charge just set the battery charging limit to 50% or similar. One downside is the risk of the Tesla vehicle being damaged while plugged in during an electrical storm. The risk of this happening is relatively small but the potential damage to the Tesla vehicle could be quite extensive, even a total loss.So here is a question regarding a situation that some people like me might have. Primarily I WFH and go into the office twice a week. At work, I have free charging. Unless we go away, we typically don’t put a lot of miles on the Tesla during the week. When I get to work, if I’m at 75%, it’s hard to justify taking up the charger space for just a 5% charge. If I plug in the car every night, I will never get the charge low enough to justify it either. I would rather not charge at home so when I get to work, I might have 50-60% which would justify plugging it in. Since the charge is always pretty high, I don’t have a concern of risk of draining the battery for 2 or 3 nights.
Anyone else have this issue? Any recommendations? I was wondering if I could plug it in and setting charge limit to 50% (even if there is 75% charge on the batteries).
No, this is just to help humans build good habits. They don't want to hear complaints from people where they were in the habit of not plugging in often, and then the car was low, and they didn't have enough range to drive where they wanted, and they were late and angry and start telling all of their friends that "these electric cars are stupid and inconvenient".I have read multiple times that Teslas "like to be always plugged in." Is this something that simply helps with vampire battery drain/sentry mode/climate control, or does it also affect other things such as battery efficiency or long term battery life/health? How important is it?
Same question for a laptop with a lithium ion battery.if you keep the car plugged in, why not charge it to 100%
I know tesla recommend to charge up to 80% on superchargers but if you are traveling and will put miles right after charge you are okay to charge upto 100%.
but if you are using level2 home charger, why not charge upto 100% so you are good for the whole week.
Because Tesla recommends that you don't charge to 100% 1) frequently and 2) if you are not going to drive the car 'immediately'. See the Owners Manual for recommendations.if you keep the car plugged in, why not charge it to 100%
It really depends on the type of battery. In the US Tesla currently uses nickel, manganese and cobalt (NMC) lithium battery cells in most of the Tesla vehicles. Testing as well as anecdotal experience has shown that NMC batteries degrade more quickly when charged to maximum and kept charged to maximum state of charge; kept charged to a high state of charge at higher temperatures. Degraded means the battery will no longer store as much energy; limiting performance and range in an electric vehicle. Degraded in an electric shaver would mean fewer shaves; shorter run time on battery for a phone or laptop.if you keep the car plugged in, why not charge it to 100%
Two words: battery degradation. You should as often as possible, and to as low of a level as you can get away with. Ideally every day to 50% if that's plenty for you. Minimizing average depth of discharge increases battery life. Minimizing SoC you charge to also increases battery life. You should only charge to 100% when you need to.if you keep the car plugged in, why not charge it to 100%
