Is model S90D faster than S85D?
The 90D has the same performance as the 85D. However, it might be able to do more consecutive launches before experiencing lower performance than the 85D. It should seriously be a tiny difference though. Something you wouldn't notice unless you regularly clock many back-to-back launches. I'd go with the 90D just to have max range, may as well if you're already going for an 85D.
This. AFAIK, they are the same however MS gets slower once the limiter appears on the speedo, which is when the battery gets lower. The difference is the limiter should appear later on the 90 vs 85 given the same amount of driving assuming all other things are identical
