JeffK
No, first car was already made. July 28th is the final reveal, first deliveries.July 28, 2017 actually will be the first car, right?
No, they didn't remove the 2nd gear to prevent break downs. Suggest you listen to one of the founders.This is because they kept breaking... They simply took out the second gear and thus limited top speed. It had nothing to do with the inverter. Going to a single speed gearbox was never the desired outcome. It was just simpler then having it break.
Rimac found a way of doing this correctly. I'd imagine the next roadster will too.
I do agree that they at one time will need to create a new platform for the S and X, but when they do, they will be better of basing it on the Y platform. Making it cheaper and easier to build and to automate the building of the cars.What they essentially need is a new platform for the S and X, that will share parts with the 3 platform.
At one time in the early life of Model S it was some question if Tesla would open it supercharging network for cars from other manufacturers. The answer for basically an "Yes", but among other things he said something like the following (Sorry, do not remember the exact quote) "... but we will not let any car access that cant charge at the same rate as our current cars." At that time I think 90kW was the limit for Model S.Yes, but I think we are presuming that was a 75 kWh model so we might be looking at 0.9C charge rates for the 2170 cells. If that turns out to be true then the base model of about 55 kWh might be limited to something around 50 kW peak charging.
Has anyone done the math when it's 94 degrees out and air conditioner is cranking like today or when it's 15 or 20 degrees like we sometimes gets in NJ and heater is on full blast. I have not seen anything written about this
And learn the real reasons and the developments why Tesla only uses one gear (up to 155 mph, right?)
I would say the base model has *enough* range to sell out all of the production Tesla can possibly make. That's all that really matters. Anything extra would be based on what competitors might do (if a competitor comes out with a entry level premium EV with 300 miles of range for ~$35k for example).The base model still has a limited range compared to typical ICEs. Profitability is still achieved at the same or even slightly increased margins... 30% say or even 40% but why must it be several hundred percent like it is now with Model S?
S/X were 31% last year although I don't know the individual break down.Even the S have not topped 30% gross margin.
Model S margins have been, as I recall, between about 20-30%. You can read the SEC filings to see what the margins are. several hundred percent is just plain WRONG See page 45The base model still has a limited range compared to typical ICEs. Profitability is still achieved at the same or even slightly increased margins... 30% say or even 40% but why must it be several hundred percent like it is now with Model S?
Very interesting, thanks!I do agree that they at one time will need to create a new platform for the S and X, but when they do, they will be better of basing it on the Y platform. Making it cheaper and easier to build and to automate the building of the cars.
So no, I do not think Tesla will allow a Model 3 access if it can't charge any faster then 50kW at peak charging.
Not for the car... for the battery upgrade. We know the cost is lower than $190 / kWh at the pack level. Find me a battery upgrade that isn't at least twice that hence several hundred percent higher than cost. (margins are always less than one)Model S margins have been, as I recall, between about 20-30%. You can read the SEC filings to see what the margins are. several hundred percent is just plain WRONG See page 45
You are looking at totals which include leasing and service... just automotive sales in 2016 wasGross margin total automotive (Model S first full year production 2013, not shown here)
2016 23.4%
2015 22.9%
2014 27.6%
It sure is!Learning to read financials is well worth the time in today's corporatized world.
Model S/X don't break transmissions, so I guess they "do it correctly". I thought Remac was also single speed, I'll have to go double check, but then to get over 200mph ... what a great company and what a great story the founding of Rimac. Performance kings for now, IMHO. Perhaps they can become the Bosch of electric cars in EU? Interesting to see the balance between design and manufacturing at Rimac.This is because they kept breaking... They simply took out the second gear and thus limited top speed. It had nothing to do with the inverter. Going to a single speed gearbox was never the desired outcome. It was just simpler then having it break.
S/X are single speed and rimac has a two speed gearbox in the back. It's pretty cool.Model S/X don't break transmissions, so I guess they "do it correctly". I thought Remac was also single speed,
YepNot for the car... for the battery upgrade. We know the cost is lower than $190 / kWh at the pack level. Find me a battery upgrade that isn't at least twice that hence several hundred percent higher than cost. (margins are always less than one)
example $190 cost sold at $600 = 68.3 percent margins and the price is 316% higher than cost
You are confusing the cost of one component - the battery cells - with the cost of the battery pack.Not for the car... for the battery upgrade. We know the cost is lower than $190 / kWh at the pack level. Find me a battery upgrade that isn't at least twice that hence several hundred percent higher than cost. (margins are always less than one)
No the $190 quote was at the pack level by the VP of investor relations.You are confusing the cost of one component - the battery cells - with the cost of the battery pack.
Good to see. I'm more conservative and seldom trust Wall St. analysts (unless of course they write what I like to think is true. ;-) ) hope you find time to watch the youtube clips, you will enjoy. Battery costs are coming down so fast. Have you listened to Tony Seba talk about disruption? RethinkXNo the $190 quote was at the pack level by the VP of investor relations.
Tesla confirms base Model 3 will have less than 60 kWh battery pack option, cost is below $190/kWh and falling
All the cooling and the chassis are included.
Hmmm.... that's strange. You should get solar if you can afford it.Yes, cheaper than going month-to-month. It's 0.075 per kWh, ending up with an average of 0.115 once the other fees are factored in. I didn't go for the cheapest rate around as I've opted for a 100% wind plan to support the expansion of green energy.
Yes, but living in the Houston metro which means my biggest electrical expense is AC during the day. When I worked at an office I'd kick the AC up during the day, but now that I work from home it needs to be comfortable enough for me to work so opting for free nights but more expensive power during the day may not be a good idea (especially since working from home means I don't put as many miles on the car as I used to). Additionally, this is my desk, so I keep the AC turned down a little lower than I used to:
Yep, and kilometers of spilled ink will be spilled in poorly spelled and constructed angst by the ignoranti.Downside: its range will fluctuate more with conditions. E.g. crosswinds or accumulated snow/ice on the vehicle, things that increase the drag coefficient, will hurt it more.
