Does regen have anything to do with the motors? Or are they separate? Wondering if rear wheel drive only had rear wheel regen as well.
So does the standard range plus have the same regen or not because it only has one motor for rear, that's my question. Not how it actually works but specific to Tesla, how does it work?The specifics are different: Early models regen is not as strong and could be adjustable. Newer models have stronger regen and I think the manually adjustable button is gone...
However, the principle is the same: As a motor, it takes in energy. As regen, the motor now becomes a dynamo or a generator that produces electricity. To generate electricity, the dynamo takes in mechanical energy. You can create electricity from some First Aid flashlights and radio by spending your own muscle energy by turning the hand crank. In your Tesla, it uses the moving motion of the car to crank its dynamo (motor), thus, the acceleration slows down.
Yes. It does make sense.So does the standard range plus have the same regen or not because it only has one motor for rear...
So the SR only has half the regen strength or do they double it for the rear?Yes. It does make sense.
The principle is the same. The specifics are not: 1 is not the same as 2: Your 1 motor version or 2 motor version becomes 1 dynamo or 2 dynamos. The money is not the same, the amount of regen energy produced is not the same. You pay for the specifics.
For example, the rear-wheel drive Standard Range Plus and my 2018 Model 3 Long-range both have only 1 motor maximum for each car and located in the rear. So those motors can become a dynamo (1 maximum for each car because they don't come with 2 motors each.)
If you pay more for a dual version, you would have 2 motors for each car (1 in front, 1 in rear). Both of those 2 motors can become 2 dynamos. When those 2 motors become a dynamo or not depend on when you can get a regen or not (when the motor output is paused and the kinetic energy of wheel motion turns the dynamo to create regen electricity.)
Right on. Main reason I ask is I want to know if regen is weaker feeling on the SR+ which seems not true if the overall efficiency rating is higher. But maybe there are other factors that win out on efficiency like the 500lbs difference.The detail missed so far is that the battery cannot charge at an infinite rate. So the limit is not the motors in many cases. Just like supercharging can only drop about 50 kW into a battery with 90% SoC, regen can't do more than that either while keeping the battery healthy. And you don't want regen changing dramatically as SoC changes. More motors doesn't change the battery, and just one motor in a Tesla can easily do 50kW.
Additionally, Tesla does not want the car to decelerate too much in regen mode- it needs to be comfortable and safe to people behind you. So they actually limit regen to G's of deceleration (not watts), and G's times mass equals watts, independent of what the motor(s) could actually do.
Yes, the rear tires wear a bit faster.Wouldn’t that wear out the rear tires faster and more importantly be dangerous to stop the car only using the rear wheels? Or do the front breaks engage to balance out the breaking?
Brakes. Braking.With the SR+ regen only from the rear, the rear wheels are breaking the car and the front are doing nothing? Wouldn’t that wear out the rear tires faster and more importantly be dangerous to stop the car only using the rear wheels? Or do the front breaks engage to balance out the breaking?
Kinda disappointed to hear there is no regen from the front end. Means the front wheels aren't engaged in the braking stage but it sounds like much more wear on the tires in general. But it is also 500lbs lighter but still.Yes, the rear tires wear a bit faster.
No it's not unsafe. Regen won't lock up the tires, and it doesn't really matter until that happens. The front brakes do not engage unless you press the brake pedal.
So either the regen works from the front as well even though there are no motors, or, they have no idea what I'm asking them.
I just don't know how or where to verify any of what I'm hearing back and frankly I'm not sure how you guys have answers either.
You are WAY over estimating how much wear 0.3G's of braking causes, and the fact that front tires often wear faster due to turning loads and friction braking loads. Just rotate your tires every 5-10K miles and move on.Means the front wheels aren't engaged in the braking stage but it sounds like much more wear on the tires in general.
Lolz. Elon is the one suggesting cars don't need steering wheels anymore since FSD is so close (and has for 5 years now).If I ever host a podcast featuring Elon, I'll be sure to ask these questions.
I feel you. I'm basically rhetorically stating that they are telling me a load of crap. There's probably no way there's some part that is only for regen but I guess I'd believe it if there were, it's why I'm asking but I also feel like it would be more common knowledge as well. But maybe not, nobody seems to really talk about the differences in regen on the surface but you do hear equally technical conversations about the w piece cast and stuff like that.Dude, regen works by running a motor as a generator. It's impossible to have regen from an axle without a motor on it. This is basic physics and how all EV's work. What device on the front axle would convert torque into electricity but can't do it the other way?
But if you're so sensitive to this, buy an AWD.
Tesla salespeople are not technical.I'm basically rhetorically stating that they are telling me a load of crap.
Yes the hold feature is what you are talking about and as I mentioned I'm very familiar with all the brake settings. My experience regarding the strength seems to be independent of all the variables one can be in control of or even observe so I'm trying to understand.Another point: When driving my Tesla Model 3 LR RWD, I tend to modulate the regenerative braking by letting off the accelerator enough to get the deceleration I want, much as I modulate the brakes in a car without one-pedal driving. I don't usually lift my foot entirely off the accelerator so as to get maximum regeneration. When I do that, I usually need to stop more quickly than regeneration alone will handle, so I move my foot over to the brake pedal to get its effect, too; or it's at the very end of a stop at a light or whatnot. I find that this produces the most comfortable ride -- switching in a binary way between acceleration and full regenerative deceleration is jarring to me. (This is one gripe I have with Autopilot; it tends to toggle quickly between acceleration and deceleration when going around curves or whatnot, rather than picking an appropriate intermediate speed and sticking with it.) In other words, even if a dual-motor Tesla could produce more regenerative braking than a RWD model, that wouldn't make much difference to how it's used -- at least, not to me. If you prefer a more binary driving style (full-throttle acceleration and full regenerative braking, with little in-between), then it might be a different story.
Also, there is an option in the Tesla configuration menus to enable a full stop without touching the brake pedal. (I don't recall its name, but it's in there somewhere.) With this option enabled, the Tesla will apply the brakes to come to a complete stop once the car's speed drops enough that regenerative braking has little effect, even if you don't touch the brake pedal. This feature provides what is called "one-pedal driving" in some other EVs, and it blends regenerative braking and conventional brakes -- but only below a certain speed (somewhere between 2mph and 5mph, IIRC, but I don't recall the precise figure).
Yeah I even asked if today's model 3's come with heated steering and they said not yet. So even the non technical stuff it's really easy to get misinformed.Tesla salespeople are not technical.
On my first Tesla, they told me the only fluid in the car was washer fluid. I was standing next to the wheel, and pointed at the clearly visible brake line and asked why that was there.....
A Tesla has washer fluid, brake fluid, coolant, gearbox oil, and refrigerant. All of those have maintenance schedules in the manual. So much for one fluid.
