corduroy
I am not trying to sell you something. But you took delivery in warm weather in Minnesota!! You've not experienced a winter with your Tesla yet. Please start looking here and on TM (particularly under Model S and X) for range loss in cold weather. I have nothing to gain in my prediction, but I suspect that your 120v charging is not going to keep up with battery charging and you will likely see no gain after charging for hours. You need your battery warm/hot when you leave in the a.m. This cost your range to warm the battery and the cabin. You want the charge to finish just about the time you are ready to unplug and leave. Well finishing and unplugging at the same time should not be a problem for you, I am betting (I am concerned for you) that you will still need charging and have not topped off. Even if you are charging in a garage. I hope your garage is heated.
I've had my S's now for almost 6 years. And in a warm climate. Although, I've not personally experienced this issue, I have read many threads and posts about it. I recommend you get some quotes and see if you can at least install or re-route/share your 14-30 dryer circuit with your car. Even if you think you don't need more charging capability, at least be ready to add.
Good advice. I need to research the cold weather effects on the battery some more before the cold is upon us here. I should still have enough range to spare, but probably not as much as I was thinking!
