TexasEV
If you search the archives you will find hundreds of posts in 2013-2014 debating the merits of dual chargers on the early Model S. It was a hot topic back then...
One use case that everyone's missed - if you are on a TOU rate plan with a narrow cheap nighttime window, dual/hi amperage chargers could save money on your electric bill if it allows you to do all your charging during that window vs spilling into a more expensive period. However, it's unlikely you'd ever recoup the cost of the faster charging option.
My CPO came with dual charging. I've used 80A chargers several times while parked for meetings, dinners, etc. that include a 150-250 mile round trip. Tesla has since opened or announced superchargers near or on the way to these sites, so I wouldn't pay extra for it on my next car.
And I was much more pro- then. The landscape has changed much, IMO.If you search the archives you will find hundreds of posts in 2013-2014 debating the merits of dual chargers on the early Model S. It was a hot topic back then...
Don't want to put words in your mouth, but I suspect you're referring to the increase in supercharger density and breadth. If that's what you're saying, I completely agree. In 2012, it made sense (to me at least) to "prepare even more" for charging scarcity by picking up items like the Roadster adapter. These days, if I'm travelling out of supercharger range it's... well... a different kind of trip where I have more time and the time factor on charging is less of a concern.And I was much more pro- then. The landscape has changed much, IMO.
Agreed.... that's indeed what I was talking about primarily, and referred to it up thread a bit.Don't want to put words in your mouth, but I suspect you're referring to the increase in supercharger density and breadth. If that's what you're saying, I completely agree. In 2012, it made sense (to me at least) to "prepare even more" for charging scarcity by picking up items like the Roadster adapter. These days, if I'm travelling out of supercharger range it's... well... a different kind of trip where I have more time and the time factor on charging is less of a concern.
There are other options between 1 and 10 kW. The semi-legendary @Bighorn ,who has over 197,000 miles, has been using a 30A circuit the whole time.The important thing for home charging is to get to at least 14-50 (240V @ 40A, or slightly less accounting for wiring/losses) ASAP. You definitely feel range anxiety (at least I did and do) limited to 120V @ 12A (standard household outlet).
On aspect you might want to consider is that if you have dual chargers, you can set your amps to 40ish and split the load between the two chargers (assuming you have the older style 40a) and provide a light load for each charger. This will extend the life of the charger modules in the car. There have been reports of the modules failing due to load and splitting them can increase their lifetime.
Is that worth the $2000 upgrade? No, probably not, but it's an additional aspect to consider. You wouldn't be getting the faster speed charge at home, but as others have already said, you don't really need it. It would be nice on rare instances on trips where it's available, for sure, though... but as others have said, it's unlikely it's worth the money.
My impression of how it works with HPWC...Not sure the power would be split. I think the first 40A goes to the first charger and the second charger would receive any surplus.
I called Tesla and they verified our S contains the 72A hardware and that upgrading from 48A to 72A would only require a software change.
Though unless Tesla lowers the price of doing the update - unlikely we can justify it, since 48A charging should be fast enough for our home and road charging..
On my 80A dual charger S, using <= 40A only the first charger activates. Using > 40A, it splits between the two chargers.
There's been discussion that the 48A and 72A chargers are built internally from 2 or 3 24A units, but I haven't seen anything about load sharing across the units internally.I'm not sure how the new 48a chargers do it though, is there only 1 that goes up to 72? I assume so, so if you have a refresh then it doesn't really matter what you do.
Overall, it depends on the individual's charging needs
