Is the missing bolt important?
DCast1
11
0
Ohio
Anybody know what the bolt about 2 inches in front of the front jacking point under the car up inside the little compartment is for? There is a little plastic cover 1.5 x 1.5 inches that opens by swinging down to access the compartment. I noticed the little door was open this morning when hosing off the wheelwells and looked inside - there was an empty hole in the one that was open (drivers side) and the one on the passenger side does have a bolt in the hole for comparison.
Thanks!
roblab
3,348
2,399
Angwin (Napa Valley) CA
Doesn't sound like tow hook under the middle of the car. Could be one of the battery bolts to hold it to the car -- or something else. I'd ask Tesla. Betcha they'd know. And it looks like nothing will fall off before Monday.
jjcyr
22
13
Florida
Is it really a bolt? Sounds like you are describing one of the plastic rivets that hold the plastic trim between the battery case and the outside edge of the car. Can you post a picture of the spot you are describing?
DCast1
11
0
Ohio
Nope - definately not a tow hook. Must be kind of important though to have its own little compartment. Can't take a pict as too dark now. Will post one in the AM. Its literally 2 inches in front of the front jack point and the little door is completely hidden unless you know its there. Serious mystery!
