That is fantastic! I got a MS 90D in Dec. 2016. I've got about 7K miles. My 90% has dropped from 266 to 258 (3%). I mostly SC (about once a week), with an occasional home charge. I'm in SoCal so the weather is mild.
I've supercharged a few times, but the last time was in October. Tesla also suggests conditioning the battery from time to time and that helps keep the range up. The pack will charge to the state of the lowest cell and one or a few cells can get out of sync with the rest and artificially lower the rated range of the pack.
If you set charging above 90%, the system will rebalance those cells that have gotten out of sync. I do charge to 95% occasionally and then try to drive the car right away. After the last time I got the car back from the service center, they had set it to charge to 100% for some reason, even though they didn't charge the car at all when it was there. I caught it when the charge got up to 98 or 99%. I then unplugged the car and ran the heat until the charge state dropped to 95% (I wasn't planning on going anywhere right then).
It didn't seem to damage anything and I noticed the car started reporting 269 miles at 90% again. When it was new, it would report 268 or 269 at 90%. Kind of half and half. Last winter it got consistently down to 268 almost all the time, but now it's back to a mix of 268 and 269 after the accidental near 100% charge.
If the car has been sitting for a couple of days, the range can drop to 267 and occasionally 266. I've heard if the car is sitting plugged in for many days it only tops up every third day or so. There will be some vampire loss as the car sits with no charging.
