Is there a delay start feature for charging
Discussion in 'Model S: Battery & Charging' started by cmorn, Sep 13, 2013.
  1. cmorn
    cmorn Member
    Atlanta, Georgia
    I ordered my Model S this week. Georgia Power has a special rate for PEV owners, highly discounted between 11pm and 7am. Is there an automated way to delay the start of the charging process?
  2. Chris
    Chris Member
    Maryland
  3. bhuwan
    bhuwan Supporting Member
    Boston, MA
    Yes there is. You can say start charging at Z time and it won't start using energy until then
  4. caddieo
    caddieo Member
    Palm Coast, FL
    #4 caddieo, Sep 13, 2013
    You open the charging screen on the center console and you can set the time that you want charging to start. You can also set the number of miles you want to charge to, and the amps (which pretty much determines how fast (mph) the charging will go. I've got mine set to start at midnight and it's usually done when I wake up.
  5. aviators99
    aviators99 Model S - R140
    Weston, Florida, United States
    Huh?
  6. caddieo
    caddieo Member
    Palm Coast, FL
    Oops! Original post corrected. :wink:
  7. huntjo
    huntjo Member
    Fort Collins, Colorado
    Yes
  8. aviators99
    Well, I still don't know how to set the miles to charge to??
  9. smd
    smd Member
    Lafayette, CA
    On the charging screen, touch Set Charge Limit, then slide the limit along the battery graphic to anywhere you want, typically 60-90% or 100% for max charge. Now the charging will stop at that charge level in your battery.
    Changing the amps on the charge screen will change the rate at which the battery will charge. If you're at the max amps for your car and it shows that it will take 4 hours to charge, then lowering the amps to half the max amps will increase the charge time to about 8 hours.
  10. aviators99
    I wouldn't call that "miles". I would call that battery percentage. At least for me, that doesn't translate predictably to miles (even rated).
  11. huntjo
    huntjo Member
    Ok fine there is no way to set it to "number of mile to charge to". Rated and ideal miles have always been calculations based on the %charge state of the battery. Just like some ICE cars show a dial with a % of gasoline left, and newer ones calculate how many "miles to empty" based on your usage(mpg).
    Unless you have a vehicle whose propulsion is strictly dependent on number of yardsticks you lay behind it, I don't think any vehicle can be filled/charged/set to a certain distance.
    Just pick a percentage with room for extra fudge factor or fill'er up like a gas tank.
  12. liuping
    liuping Active Member
    San Diego
    Is there a way to set when you want it done charging, instead of when you want it to start? I've looked through the manual on my reservation dashboard, but it does not even mention setting a start time, which I know is available. :)
    I'd like to make sure it's done to the specified % charge by say 6am (when the rates go back up). If it needs to start before midnight to get there so be it.
  13. jerry33
    Texas
    Not at present. No doubt it will be there in some future release. However, if you have a regular commute, it won't take you very long to figure out when the start time needs to be. You can always check it with the app if it's getting close to the time you want to turn off (until you have it figured out).
  14. Nrk7001
    Nrk7001 Member
    Mesa, AZ
    This option is great, thanks for sharing. I can now set it for my time of use plan. Our electric company has a cheaper rate at certain times now i can have it start charging at 9pm when its cheaper. Check withdyour electric company to see if it has this plan
