Is there a trick to plug in Level 2 charger with the Tesla adapter provided?
Discussion in 'Model S' started by Raza-Khan, Mar 26, 2016.
Tags:
  1. Raza-Khan
    Raza-Khan Member
    Maryland
    Hello folks
    This is for 2013 Tesla Model S 85.
    Yes, I have read the manual and it seems "interesting" to say the least when the car would like to me to plug in a regular Level 2 charger (J1772) with the additional adapter. Sometimes it wants to gets plugged in and sometimes it does not.
    If some one can offer me some help, that would be awesome! Again, this is for non-tesla level 2 charges but using the Tesla adapter.
    Thanks all!!
  2. jerry33
    Texas
    Unlock port from dash. Attach the adapter to the cable. Plug into car. The trick is to leave the adapter connected to the cable until it's removed from the car after charging.
  3. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    What specifically is the problem you're having?
  4. StaceyS
    StaceyS Member
    Bend, OR United States
    Also, be aware that the charge port will "lock" itself after a certain amount of inactivity, preventing you from plugging in anything. You sort of need to juggle opening the charge port door, getting the adapter out, activating the J1772 charger and getting it plugged in before the charge port locks itself.
    I'm not sure how long it stays unlocked for, but you can hear it when it locks, its a good solid click. If it locked itself, just go to the control panel and click the "Charge Port" button again.
  5. mikeash
    mikeash Active Member
    Fairfax, VA, USA
    Keep in mind that you can unlock the charge port by holding the trunk button on your key fob for three seconds. No need to mess with the screen in the car if you're already out and next to the port and need it unlocked.
  6. ken830
    ken830 Model S 85, Model 3 Performance
    San Carlos, CA
    Although neither should be very difficult at all, unplugging is a bit trickier because you generally need to press the button on the J1772 to get the car to unlock the charge-port, but doing so will also disengage the J1772 plug from the adapter. If you don't pull them out together, the adapter could be locked into the charge port, and you'll have to unlock it to remove it. The "trick" is to use two hands to remove both plug and adapter at once.
  7. Raza-Khan
    Raza-Khan Member
    Maryland
    Thank you all. My problem was removing it. I will try those tricks
  8. Raza-Khan
    Raza-Khan Member
    Maryland
    Yup..tricky indeed
  9. Raza-Khan
    Raza-Khan Member
    Maryland
    That is so awesome to know. I will try that.
  10. Raza-Khan
    Raza-Khan Member
    Maryland
    Removing the adapters with J1772 charger
  11. Raza-Khan
    Raza-Khan Member
    Maryland
    Yes...removing it is my frustration.
  12. murphyS85
    murphyS85 Member
    Horsham, PA
    If you are right handed, wrap your left hand around the bottom of the adapter and the J-1772 plug. Push and hold the button on the J-1772 handle with your right thumb and then pull the whole assembly out of the car in one smooth motion. Then you can separate the adapter from the plug.
  13. whitex
    whitex Well-Known Member
    Seattle area, WA
    Also, on recent models (I think late 2014 and on) you can just push on the little charge cover door and it will open as long as the car is not locked. Most useful when connecting J1772.
  14. Raza-Khan
    Raza-Khan Member
    Maryland
    So, clicking the trunk unlock three times or hold it for three seconds did not work. But what seems to work is to slightly unclick the Level 2 charger and use both hands to take the charger and adapter out at the same time. I hope that they come with a better software update for this one.
  15. Raza-Khan
    Raza-Khan Member
    Maryland
    I understand... but does not comfort me.... lol.... with a 2013 :)
  16. Raza-Khan
    Raza-Khan Member
    Maryland
    Thank you!! This is the only technique that is working for right now!!!
