Is there a way to ignore threads?
Discussion in 'Site Feedback' started by James Anders, Nov 13, 2016.
  1. James Anders
    James Anders Member
    Southampton, PA
    Just curious if there's a way to ignore or not see a given thread?
    -J
  2. BluestarE3
    BluestarE3 Active Member
    Norcal
    Don't open it if you're not interested in it?
  3. Garlan Garner
    Garlan Garner Well-Known Member
    Chicagoland
    Go to the thread and click - unwatch / unfollow in the upper right hand corner of the thread .
  4. mblakele
    mblakele radial cross member
    SF Bay Area
    I wish this forum had a "kill thread" feature, but it doesn't. Here's what I'm doing: it's a bit technical, using Stylish for safari. There are similar extensions for other browsers, and they're useful for minor UI customization too.
    .messageList {
    display: none !important;
    Add the thread ids you want to block to the regex group. Thread ids are visible in the location bar whenever you're viewing a thread.
    Note that this won't block threads from search results, including the "new posts" list. But if you inadvertently open a thread you've "killed", at least you won't see any of the posts.
  5. GaryREM
    GaryREM Member
    Fairfax, VA
    Could we add something like [TH] Ignore More to be able to ignore threads? The biggest problem is something like the Model S forum which has many items updated regularly which I have to work through again and again.
  6. Garlan Garner
    Chicagoland
    At the top of the thread...click on "unwatch thread".
  7. GaryREM
    GaryREM Member
    Fairfax, VA
    This thread has "unwatch thread".
    However, only option I see on other threads is "watch thread". I want them to not show up so my list is shorter.
  8. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    Because you've posted in it, you are watching it (according to the default rules; you can turn off the 'default "watch what I post in" rule'....).
    Unless you watch entire forums, you won't watch everything automatically.
