Is there a way to prop up the wipers in advance of snow
Discussion in 'Model S' started by mrjedistud, Feb 7, 2016.
Tags:
  1. mrjedistud
    mrjedistud Member
    New York
    You know the trick that people do before a snow storm by propping up the wipers to make scraping off snow easier. Can you do that with the model s. Doesn't seem you can since the arms are recessed under the hood. Experinced owners please comment. Thanks.
    Btw after driving ICE cars it's weird that the hood doesn't melt off the snow and ice since it doesn't generate heat.
  2. Plan B
    Plan B Active Member
    EARTH
    Yes, you put them in "service mode" under settings.
  3. GlmnAlyAirCar
    GlmnAlyAirCar Member
    Southeast PA
    No, this won't work. The wipers will move up but they still can't be pulled away from the windshield to a position where they will stay. All I can think of is to put the wipers in service mode then place something under them (maybe some sort of plastic box) to keep them off the windshield.
  4. SabrToothSqrl
    SabrToothSqrl Active Member
    PA
    I never knew why people did this... but I'll take that it may make snow removal easier.
    Using your iphone to set the car to 90, even easier yet :) every so often just set it to hi, and the snow should melt off.
  5. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Yes, move the wipers to the service position and place something small under each wiper arm (not the blade) to elevate the blade an inch or two above the window.
    Not as convenient as simply grabbing the wiper arms and lifting them to near vertical and letting go.
  6. jtpassat
    jtpassat Member
    Providence, RI
    yup - makes snow removal easier.
  7. MorrisonHiker
    MorrisonHiker S 90D 2018.48.12.1
    Colorado
  8. mrjedistud
    mrjedistud Member
    New York
    Funny you say that, I literally saw one today for the first time.
  9. ElectricTundra
    ElectricTundra P85D AP1
    Tundra
    I've got a piece of canvas that's maybe 15" x 5' that I toss across the lower part of my windshield and wipers if it's outside in a snow or ice storm. Works great. Easier to toss across, retrieve, and shake out than the larger full covers.
  10. AWDtsla
    AWDtsla Active Member
    NE
    This is counterproductive with the cold weather package. Use the windshield heater to free the wipers from the normal position.
  11. artsci
    artsci Sponsor
    Timonium, Maryland
    Not so. In service mode they can be pulled away from the windshield and stay in that position. I know -- did that in our 30" snow storm several weeks ago.
  12. Jaff
    Jaff Active Member
    Grimsby, Canada
    Saves your blades when you get freezing rain too...
  13. dgpcolorado
    dgpcolorado high altitude member
    The Western Slope, Colorado
    It helps with keeping the wiper blades from freezing to the windshield. If the car is warm when you park it, the falling snow will melt and if the temperature is well below freezing the wipers will freeze to the windshield. If you forget to free them after scraping the snow/ice off the windshield, you might burn out the motor when trying to use them.
    FWIW.
  14. new_user
    new_user EFF OIL/MD
    MD/USA
    Yes, to the above..in addition. If you mistakenly leave your windshield wipers on by mistake (or have them set to intermittent) you can tear the wipers or break the motor assembly.
  15. green1
    green1 Active Member
    Calgary, Alberta, Canada
    The wipers can not be pulled away from the windshield to a position that they will stay. The last time I tried it ended up resulting in 2 ranger visits to fix.
    You could put them in service mode and then lift them a little bit (not much) and put something under the arms (a friend of mine used to use film cans, but good luck finding those in 2015)
    But unfortunately these wipers are a horrible design whee pulling them up results in pieces of metal going flying (and the wiper still not staying)
  16. dmd2005
    dmd2005 Member
    Abbotsford, BC, Canada
    A $20 frost blocker from Costco solves the problem. I use it on my Toyota Tundra all the time and have one in the trunk of my MS. Takes 30 seconds to put the frost blocker on and 30 seconds to roll it up and put it away.
  17. mknox
    mknox Well-Known Member
    Toronto, ON
    Very common in snow belt areas. This image is just from Google, but almost every car in my work parking lot would look like this:
  18. green1
    I wonder if it's an eastern thing? I see the occasional car here do that, but it's quire rare, and I've never done it in my whole life.
    Don't try it on your Model S though, the wipers don't do that...
  19. mknox
    Toronto, ON
    I always did this mainly to prevent the rubber blade from freezing to the glass. More than once I tore the rubber right off the arm when trying to extricate it from the window. If you turn them on while frozen, you can damage the motor mechanism as well. The issue (for me) is that the car would be warm when parked and snow falling would melt, run down the glass to the wiper area then eventually re-freeze as the car cooled down.
  20. MorrisonHiker
    Colorado
    Before moving to Colorado 20+ years ago, I'd never seen it (even in Montreal where they have some intense winters). Some people here do it but I've never bothered. We don't have ice storms like other parts of the country and usually all I have to do is quickly scrape along the edge of the wipers.
