Is there any kind of recommended "break-in" steps?
Shygar
925
517
Pleasant Hill, CA
I know with ICE cars some people recommend to drive it easy the first 1000 miles and do an oil change after that. Some also recommend to bed the brakes (stop very hard a few times).
Is there anything like that for Model 3 or Tesla's in general? Like should we avoid doing a full 100% charge for a period of time (or immediately do one?) or drive it easy in the beginning?
FlyF4
Son of a MX
Mar 21, 2017
823
548
moved to San Diego
If there is, then I don't know about it. As you know with ICE cars, the main reason for a recommended break-in period is because of the transmission and engine, which of course the Tesla doesn't have :D
As for charging, in general I would not charge to 100% unless you are immediately going out on a long trip. Even then, I only charge to 90-95% and I try to not let it get below 20%. There are a lot of varying opinions about this. Just from an electronics engineering perspective, I don't go outside those numbers.
Reactions: Shygar and vrykolas
Shygar
925
517
Pleasant Hill, CA
Haha thanks. I assumed as much. I plan on not charging over 80 or 90% on a regular basis, but just thinking I want to charge to 100% when I first get the car to make sure it shows at least 310 miles of range. Just wasn't sure if I should be charging and discharging the battery a few times before doing that, sounds like there's no need for any kind of break in, which is what I suspected.
TexasEV
7,640
8,464
Austin, TX
No. Just enjoy your car and let the battery management system manage the battery.
scrapps
213
212
Wilton, CT
Tirerack recommends 500 miles for tires.
Some of the lubricant stays on the surface of your tires, reducing traction until it is worn away. Five hundred miles of easy acceleration, cornering and braking will allow the mold release lubricant to wear off, allowing the other tire components to begin working together.
FlyF4
Son of a MX
Mar 21, 2017
823
548
moved to San Diego
Sound like you are buying the 100. "At Least 310 miles" on the first charge? Well that might be a stretch. 300 or more is likely, but don't be surprised that after a few months if it drops to 290-295 on a full charge.
RSavage
12
26
Encinitas CA
500 miles seems like a fairly extreme CYA number...but I suppose that's the world we live in.
Just use your head and enjoy.
viper1619
13
10
Tucson
Concur with the above guys.
Asked my delivery guy the same question as I picked it up last week, he said no break in required. I wasn't aware of the tire lubricant in the message above, but I also put 700 miles on it driving back to AZ.
Reactions: Shygar
