This article talks about the paint
Some cool info on paint colors and types (single vs multi-coat, etc.) from a pro
Found this on Facebook and found it very informative. Gentleman’s name is Tom Kellogg:
“Folks: As a professional painter, some of these terms get kind of vague and in any case they can be intentionally so. So here's the deal: Most of the old traditional paints were single base-coat paints. That is, once the primer was on, the color coat (base-coat) was all there was on there. In fact, it is most likely that Tesla's standard black finish is a single stage paint. It may have a clear coat on top of the black base-coat, but not necessarily. The rest of the Tesla finishes are at least BC/CC finishes. BC/CC stands for "base-coat" and Clear Coat." Tesla's silver, midnight silver and possibly the black metallic finishes are BC/CC systems since they have a single base layer and clear coats. BC/CC systems were developed a while ago, mostly under pressure of the environmental regs. first in place in Europe and now here in the US. Generally, these systems use much lower VOCs in the paints and now in some cases, they are water based systems. OK, now for the more expensive finishes. Here is where we get into tri-coat and multi base-coat systems. I don't know exactly what Tesla is using for their blue and red, but effectively you can't shoot that kind of red in production without it being at least a multi-coat base system. That means that after the primer is on there, there are at least two DIFFERENT color layers before clear-coating. Same thing with the pearl white: primer, solid white base, pearl base, clear coats. Ford has a current color similar to Tesla's red that you see on some of their vehicles. Lovely, but I've shot some if it and while applying the two different base coat layers isn't difficult, it costs huge amounts of money. And that's where the paint up-charges come from. More labor, more time, more expensive materials. If they want to charge me 1,000.00 extra to go from black to blue, I get it. Actually, it's a deal. Thanks for reading”
Show less
