I’ll give you the benefit of the doubt and assume you actually don’t think you’re being a condescending jerk for absolutely no reason whatsoever.
Well, I'm sorry you feel that way but tire pressure is critical to the cars performance and safety not to mention energy consumption and tire life. Regular checking of tire pressure is something motorists have been doing since tires first held air. Most people don't like to get flat tires which is often the result of running low air pressure.
I’ve been driving for 20 years. I’m well aware of how tire pressure affects the car’s ability to drive. What I’m trying to tell you is that I don’t understand wtf you think I’m supposed to be doing to “monitor” the tire pressure. The car has a freaking tire pressure monitor that tells me when it’s low. That monitor is the very SUBJECT of this entire thread.
This is where you could have a better understanding of the TPMS and tire pressures. The TPMS tells you the current pressure of the tires which is often different from the cold pressure. It doesn't alert you to low pressure until it's
really low. That means it's up to the user to be aware of the situation with your tires. The Owner's Manual tells you how to do this (with a manual tire pressure gauge). Yes, until we have non-pnuematic or self-inflating tires the person responsible for maintaining the car actually has to check pressures manually. At least if you believe what the manufacturer of the car tells you.
In 20 years of driving, I’ve never had a tire pressure monitor go off when the tire isn’t low, and I’ve never had a tire low without the pressure monitor going off. Thus, perhaps unlike you, I’m not so paranoid as to feel the need to manually check pressure every other week.
Again, the low pressure alert will not go off until the tire is
really low. That means it was underinflated
before the low pressure alarm went off.
Do you also spend your saturdays testing out all the locks on all the doors in your house just to make sure they still lock?
No, we use a special kind of door lock that doesn't contain any air pressure inside. That means when they are moved in the "lock" position, they stay locked until someone unlocks them.
Are Sundays your “test all the smoke detectors” day? Generally, the average human doesn’t spend his/her time and energy to constantly and repeatedly reassure themselves of the continued functionality of components which have a sub 1% failure rate at any given moment.
I put new batteries in the smoke detectors once a year and they don't contain any pressurized air that could leak out.
And by the way, I live in Southern California. The “cold season” here is 60 degrees, so while you seem to think weather is paramount to your driving and maintenance decisions wherever you are in the world, they are decidedly not here.
It's not the absolute temperature that matters, it's the change in temperature between seasons or weather systems. I've ridden motorcycles extensively in California and have seen the temperature swing 50 degrees in one day. Unless you live in a climate like Hawaii the temperature will probably change enough to have a considerable effect on tire pressures. Regardless, a tires casing allows a small amount of pressure to escape at all times so it is necessary to constantly replace the escaped air or you will be driving on under-inflated tires.
And I don’t understand the “responsible motorist” quip. My thread is about how to get rid of warning messages, and you’re making a blanket judgment statement about how responsible of a driver I am??
I consider anyone who drives on the same road as other motorists (which may include my loved ones) and who thinks it's unecessary to check tire pressures regularly, to be negligent (and yes, irresponsible). Driving is not a right and it carries with it certain responsibilities. I don't want to be on the road with a bunch of ignorant people who don't know the first thing about maintaining their car in a safe and reasonable manner. And, no, going 4 months without checking your tire pressures is not what reasonable people do.
Knowing where to look for the manufacturers recommended pressures and how to check the pressure is in the class materials that beginning drivers must learn before being awarded their drivers license. I've even heard of beginning drivers being sent home without a license for showing up to their driving test with under-inflated tires. Immediate fail. How you could not know this is beyond my comprehension.
