My understanding is that it does reduce direct battery heating but has no effect on the latent heat your battery will receive while driving. And it does reduce cabin heating too but if you are in that mode you probably should already reduce it yourself and turn on the seat heaters.
If you do turn on range mode make sure you turn it OFF whenever you charge.
This is the misconception about the feature. The feature increases range when doing lots of short trips on a charge with pauses in between.I would never use it unless there was some reason to stretch range.
Fully agreed, the quick access menu with full car picture from above should have this, or a few user configurable options. It’s quite a waste of space menu, especially if you don’t have pano roof or sz package.On long trips you should not have it turned on. It's limits pack heating and energy In general while on long trips energy used to heat the battery in the beginning will result in a much more energy efficient remainder but that only happens on long trips like longer than one hour.
I wish Telsa had some quick access toggle on screen when just starting a drive or stopping a drive to easily switch.
I personally will almost never use range mode. Any efficiencies gained is not worth the lost of battery longevity due to thermal management being handicapped. The only chance I would use it is if I am running out of charge and won’t make it to the next charger or my car is cold soaked and I am making one short drive and then parking it again for hours.Thank you @Darmie The link is a little difficult to read, but has a very good explanation of when to use Range Mode in my 100D. (YES for long trips with highway cruise speeds. Not so much for shorter stop-and-go.)
I'm looking forward to experimenting with it on an upcoming multi-day road trip.
It also turns off running lights which saves like 2 mW or something (sarcasm but the wattage is about zero). Never figured if this was just a reminder range mode was on or WTF.
Range mode reduce battery conditioning and would likely reduce the longevity of your battery. I only turn it on sometimes if the car is cold soaked and I am doing a very short trip. Almost never turn it on.
