So I walked out into the garage a couple of hours ago and heard what sounded like an air hose leaking with a high pitched but relatively quiet whine (much different than the "normal" noises the car makes). At first I actually thought it was my garage compressor, but then I realized it was coming from my car. It sounds just like an air hose leak, but the suspension hasn't collapsed or anything (note: over the years it has done a few up/down dances). The high pitched whine almost sounds like the compressor (i.e. is there a tiny leak and the compressor is running to "keep up"), but it is quieter than I normally hear from the compressor (admittedly, I am usually inside the car).
Anyway, video below (hopefully you can get to it and hear it OK - it is most audible as I move above the tire and then beneath the car). Note there is no obvious leak at the strut air hose joint, etc.
Video of noise:
https://photos.app.goo.gl/sat5K9UVN9eWyP4P7
Car is a 2013 P85+.
Anyway, does this sound like an air suspension leak or something else?
Video of noise:
Car is a 2013 P85+.
