Is this page about monitoring from home network still valid?
cwied
867
616
San Mateo, CA
Those procedures are just an alternative to using the IP address and don't seem to work in most networks (with the exception of connecting directly to the gateway Wi-fi network). I just use the IP address directly.
PBBear
60
51
Australia
I cannot connect using any of the procedures. Each of three browsers I have tried simply time out. I know my wired connection is good, because I can access the technician's "landing" page using the IP address of the unit.
The bit where it says 'Enter https://teg-xxx, where xxx is the last 3 digits of the Gateway serial number.' could only work if you are connected to the PW2's internal TEG-XXX WiFi network. If instead you have the PW2 connected to your home LAN or home WiFi, the name 'teg-xxx' won't work and you have to use the correct IP address instead.
