^^^ Do this and be on your way.Do you have a volt meter? Test it to see if there is any voltage. Then get an insulated plier to pull it out.
How could you close the circuit by using a voltmeter? My understanding is that a voltmeter never completes a circuit connection and that it is actually an isolation circuit. Are you saying that's not correct?I would advise against testing pins with a voltmeter. If there is voltage present and you close the circuit damage may be done.
My J converter came apart tonight, and it appears that my only option is to have it towed. Is it not safe to be removed? Surely the current doesn't flow out in this way?
Oh! This happened to me a few weeks ago! So I used needle nose pliers to pull out the pins, which do come out easily. Then grabbed the plastic while mashing Unlock on the app. Came out easily. Obviously I tested the current, which wasn’t there. Your current may vary! So test. I bought a new J adapter and it went fine after that.My J converter came apart tonight, and it appears that my only option is to have it towed. Is it not safe to be removed? Surely the current doesn't flow out in this way?
