BluestarE3
I had made the same misidentification initially. The object you'd outlined in red is part of the steering column. From the angle of the shot, the display looks like it's behind the steering wheel and mounted on the do-hickey you'd outlined in red. I'm pretty sure there is still only one display and it is mounted to the right of the steering wheel as on the prototypes.From the recent release canditate photos:
I think this is a small dash built around the steering column. This could contain an LED speed readout as well as other LEDs for full beam etc.
This photo, from the same set of spy photos taken of the same car (probably within seconds of the photo you posted), was shot directly in profile:
As you can see, the object circled in red in the other photo is part of the exposed steering column, there is no secondary display mounted on the steering column behind the steering wheel and the 15" display can be seen to the right (from the driver's perspective) of the steering wheel.
The only way I can explain the apparent discrepancy between the two photos is due to an optical illusion. The perspective of the shot, lens compression distortion, poor lighting and the tendency of one's brain to fill in information that's not there (e.g., seeing a UFO in a cloud formation) result in an image that appears to show a display behind the steering wheel. Either that or the driver quickly snapped it off as soon as he realized his car was being photographed.
However, let's not forget that Elon emphatically and repeatedly said "no second display".
