Definitely let us know once you get it whether there is a change or not. I still don't know if it is a fluke or if it will be taken away after the next update again. Was extremely helpful on our recent 900 mile trip only having to charge 20-30 minutes at a time instead of 35-50. Overall reduced our total charging and travel time by about 40-45 minutes.
As soon as I receive the 2020.48.26 update I will try it out and post results. I’m currently on 2020.48.12.1
Have you actually checked battery temp? Was the Supercharger stop planned in navigation for the whole hour? Just driving at this temperature at US (I assume) highway speeds does not heat the battery enough. Either the car does it (if the charging stop has been entered long enough) before arrival or it takes some time to build it up at the charger. The latter might have happened given the start at only 45kW. One can try to Jojo battery temp up by accelerating and decelerating aggressively a couple of times. Tesla Bjorn has shown that at the arctic nicely.
I did put the charger into the navigation system around an hour or so prior to actually charging. On my way out, the nav system had me going to a closer Supercharger, but I stretched to get to a 250Kw one instead of the 150Kw. On my way back I selected the 250 one from the start.
I reported a month ago that my car’s specs were very similar to yours but that I hadn’t experienced any throttling. THEN on my mid-December trip, every SC max was.... 107 kW. Once it briefly “spiked” to 109 kW. Very definitively capped. I was able to find in my Teslafi data one almost identical prior charging session for comparison (start and end SOC, outside temp, and even same previous driving as this is a trip I make often) and the total time of my charge was only 5 min shorter when I hit a peak of 138 kW. It doesn’t appear my taper was affected. So the 5 min longer/session is not a big deal to me, but it did make me feel that my car crossed the “old” line. Your noting recent higher kW charging rate is very interesting. I have not SC’d since my mid-December trip. I will try to remember to report back in next time I SC.
Looking forward to trying the new update. I've been capped to 108kW on my 100D since August 2019 (unhappily starting in the middle of a cross-country road trip!). Tesla have been wholly unhelpful and simply stated that they "were unable to verify any faults or concerns with your vehicle's systems at this time" when I asked them to look at the problem late last year.
I have 2017 MX 90D with 52k miles. I love the 2020.48.30. The supercharger speeds are very good now. I see a peak rate of 132kw and tapering also not as bad as before. Before this version of SW..I used to only see peak rate of ~90 to ~100kw and quickly tapering. Is this some error on Tesla or a permanent change?
Old 100 packs used to receive the 108kw cap if you DC fast charged more than 15,000kwh. Not as bad as the other packs. Hopefully with new software that is removed. No one knows yet. Hopefully a permanent change that won't result in battery damage.
Thank you for the reply. I use lot of supercharging - about 75%. I'll not update my SW until a major update.
Thanks for the additional information; that aligns fairly closely with my experience. Looking forward to trying the new software (I think it's out to about 75% of the fleet now, according to Teslafi, but I'm lagging behind).
Ended up leapfrogging that update and got 2020.48.37 installed on Sunday. Tried Supercharging yesterday at a v3 station and was happy to get ~150kW peak when I started charging from ~20% SoC. I'm closer to 20,000kWh from DC fast charging now, and just over 60K miles. Glad to have this arbitrary cap removed. Had a quick look at some charging curves, and although the curve goes down faster initially, it seems to stay a few kW above the earlier curve when tapering above 50% SoC. Happy to see >500mi/hr charging, even if only for a minute or two!
