ISS had a leak caused by Russian orbital module
Discussion in 'SpaceX' started by Grendal, Aug 30, 2018.
  1. Grendal
    Grendal SpaceX Moderator
    Santa Fe, New Mexico
  2. Derek Kessler
    Derek Kessler Active Member
    Cincinnati
    My favorite part: after they found the 2mm hole and were preparing to seal it, an astronaut just stuck his finger over the hole in the meantime.
  3. Haxster
    Haxster Member
    Silicon Valley
    I wonder how many fingers it would take to plug the leaks in the White House.
    • Funny x 4
  4. Derek Kessler
    Cincinnati
    Something something shove a fist in it.
  5. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    I want to know how you find a 2mm hole in a Soyuz!
  6. ecarfan
    San Mateo, CA
    From the article, quote: “The leak has been isolated to a hole about two millimeters in diameter in the orbital compartment, or upper section, of the Soyuz MS-09 spacecraft," NASA officials said in a subsequent statement about the status of the repair work. "The rate of the leak was slowed this morning through the temporary application of Kapton tape at the leak site. Flight controllers are working with the crew to develop a more comprehensive long-term repair."
    For “Kapton tape”, read “duct tape”. ;)
  7. WentOffGrid
    WentOffGrid Supporting Member
    Warwick NY
    Looks like the fix worked. It's held pressure perfect.
    "Flight controllers at their respective Mission Control centers in Houston and Moscow worked together with the crew to effect a repair option in which Soyuz commander Sergey Prokopyev of Roscosmos used epoxy on a gauze wipe to plug the hole identified as the leak source."
  8. ecarfan
    San Mateo, CA
    Wow. How sophisticated. ;) But whatever works!
    Pretty soon those Soyuz will only be used by the Russian cosmonauts.
  9. adiggs
    adiggs Active Member
    Portland, OR
    Kapton tape - don't leave Earth without it.
    Or maybe that's - epoxy and gauze - don't leave Earth without it.
  10. Grendal
    The hole causing the issue.
    The repair.
    • Informative x 4
  11. e-FTW
    e-FTW New electron smell
    San Francisco, CA
    #11 e-FTW, Sep 1, 2018
    That looks like a drill hole. Weird.
  12. JohnSnowNW
    JohnSnowNW Active Member
    Minnesota
    How does that happen? And from the inside?
  13. S'toon
    S'toon Knows where his towel is
    AB
  14. e-FTW
    San Francisco, CA
  15. ggr
    ggr Expert in Dunning-Kruger Effect!
    San Diego, CA
    Quick plug for Robert Heinlein (from Rereading Early Heinlein, part 2 | Views from Crestmont Drive):
  16. ecarfan
    San Mateo, CA
    I’m unclear on why you say “from the inside”. The hole must have been caused by a micrometeorite impacting the vehicle from the outside.
  17. Vitold
    Vitold Active Member
    NM
    Hole must have been drilled out for epoxy fix. I do not get why they are saying that it could have been an aging or lost seal- was there a hole before?
  18. JohnSnowNW
    Minnesota
    When the story originally broke they were discussing the hole showing signs of being made from the interior, rather than exterior. Something could have changed with more analysis, I don't know.
  19. ecarfan
    San Mateo, CA
    Okay, I didn’t see that discussion. I can’t imagine something occurring inside the Soyuz that could result in a 2mm hole but of course I know very little about the detailed design and operation of that vehicle. It just seemed to me that a micrometeorite was by far the likeliest explanation.
  20. Model 3
    Model 3 Active Member
    Norway
    My guess based on facts:
    · The control-center registered a small air-leak on the station, and did not know where and/or what it was. The people on-board was at sleep.
    · The news leaked out (just like air ;) ) and the journalists started to speculate and wrote an article based on that.
    · The astronauts/cosmonauts wake up and was asked to try to locate the leak.
    · They did discover the 2mm hole.
    · The article was updated but they "forgot" to remove the speculation (word-count is word-count after all ;) )
