Everything else aside, converting a 14-50 mobile charger adapter to this L14-30R receptacle is a bad idea. The car mobile adapter can read what adapter is connected to it and adjust the max amperage accordingly. You are telling it you have a 50 amp plug. At a minimum that can trip your breaker. At a maximum it could start a fire.
You should start by throwing that out and buying the 30 Amp adapter that
@Sophias_dad suggested, or buy the proper NEMA 14-30 adapter from Tesla and get your receptacle switched over.
The mobile adapter plugs have temperature sensors in them to detect if the outlet is getting hot. Your adapter does not.
This is all sorts of bad even if you did set the maximum charging amps to 24 amps in the car. That's a software switch and it could get messed up with a software update or even someone playing with it and you not noticing.
I have the Tesla 14-30 adapter and a 14-30 outlet and the charging works fine. You should look into that.
