Issues with LED lights on trailers
Discussion in 'Model X' started by Nuclear Fusion, Nov 18, 2019.
  1. idoco
    idoco Member
    Outside Philly
    ^^This. I use the same adapter for our trailer with LED's. No issues.
  2. LukasSwan
    LukasSwan Member
    Halifax
    I have LED trailer and 2016-12 MX.
    It works great.
    But at one point the car controller had a trailer fault, and they replaced it. So maybe mine is a newer unit.
    At night, I can see the LEDs lit up all night (very low intensity) even when car is closed and locked. So still not perfect.
  3. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    Incorrect, as a blanket statement. My 17 ft trailer is 100% LED outside and inside, and all the trailer lights work perfectly when I’m towing it with my mid-2017 X.
  4. trekkie
    trekkie Supporting Member
    Wake Forest, NC
  5. mycrew143
    mycrew143 Member
    Florida
    I have a 2017 MX with tow package. I towed a 2019 Aluma 8200 H Tilt trailer that has LED lights behind my X and had no issues at all.
    No mods other than the factory tow package.
    Regards
  6. Yinn
    Yinn Active Member
    Behind you
    2016 & 2017 MX had no issues with a trailer using LED tailights. Everything turned on and worked as expected. Once again the only consistency with Tesla is that they're inconsistent.
  7. ohmman
    ohmman Plaid-ish Moderator
    North Bay, CA
    It is possible, even likely, that the amount of draw differs for different trailers/campers, and that's the reason we have different outcomes with our MXs.
  8. Yinn
    Yinn Active Member
    Behind you
    More than possible, that’s the actual answer.
    The adapter changes the resistance and draw, which is why it works with it. The hitch won’t be able to read single LED or low powered LED trailers. But if you have one that’s powered by a strip of LEDs or used redundant lights, it’ll draw enough to work.
  9. Fredneck
    Fredneck Member
    Pennsylvania
    Do you realize the problem is too little current drawn by the LEDs, right? So if your trailer has lots of LEDs, it will draw enough current that it won't trigger a problem with the controller. I don't get that a controller will kill the power if there isn't enough load. That makes no sense. Limiting power when there is too much current drawn makes sense, but not too little.
  10. Yinn
    Yinn Active Member
    Behind you
    Because it’s trying to determine if a bulb is out. If there’s not enough draw it says yes, broken bulb. With a broken bulb, you wouldn’t want to keep feeding a current as it has a potential to lead to shorts.
  11. ecarfan
    San Mateo, CA
    Yes, I do. I was pointing out that the OP made a definitive and categorical statement that was demonstrably untrue.
    I think it is important to correct posted misinformation.
  12. mswlogo
    mswlogo Well-Known Member
    MA, NH
    I don’t think that’s the issue. That’s a common issue if you change incandescent bulbs to LED within a car. Where the car knows the load range it should see and if you change it, it gets mad.
    The problem is the Model X goes into Trailer mode based on the load it sees on the trailer harness. The min load expected was to high for a LED setup. Add a little more fake load with resistors and you are all set.
    Sounds like newer Model X adjusted for this.
    It would be hard for Model X to know a bulb is out on your trailer. It could have learn mode and save it and watch if it goes lower. But I don’t know any vehicle that does that.
  13. Fredneck
    Fredneck Member
    Pennsylvania
    Give that just a bit of thought. The purpose of detecting a bad bulb is to let the driver know to replace it. Once a bulb has broken the filament there is very little chance of it shorting in any way that would cause a problem. A broken piece of filament falls across the internal wires and it burns up. If the current remains off, how will the circuit know the bulb has been replaced?
  14. Nuclear Fusion
    Nuclear Fusion Active Member
    Outside a bubble
    Ordered one. Now I need an adapter for it at both ends to work with flat 7 pin
    Any suggestions?
  15. ShawnA
    ShawnA Supporting Member
    Edwardsburg, MI
    Hi Nuclear Fusion,
    Could you please show a picture of the flat 7 pin you need to adapt to???
    Thank You,
    Shawn
  16. mswlogo
    MA, NH
    I’m no expert on all the types of trailer connectors and figured they had an adapter that would add load resistors to solve your issue. So I did a quick search and sure enough they did.
    But the one I did link is a flat blade and should plug into the Model X and plug what ever you were plugging into the Model X into the adapter.
    Googling around I see there are round pin style and blade style (in similar arrangement). I’ve only ever seen the blade style (like what’s on the Model X).
    It sounds like they sent you the wrong one? You really don’t want that many adapters, even if you find what you need. They probably offer both styles and screwed up.
    The one I linked had “blade” in the name. Which is what I think you want.
    Compare the pics in the link with what they sent. Easy mistake to make.
    Good luck.
  17. rgedad
    rgedad Member
    Fort Worth, TX
    I just bought a boat and went from DFW to Florida to pick it up. I brought with me the 7-Pin to 4-pin flat adapter cable I had used for years with my little Harbor Freight utility trailer (Incandescent lights). When I had passed papers at the sellers house, and hooked up the trailer, with the adapter, the trailer LED lights did not work - much to my chagrin. In addition the Tesla did not recognize a trailer was attached. The seller said that he had purchased a special 7-pin to 4-pin flat adapter for his car so the trailer LED lights would work with his VW. I tried his 7-Pin to flat 4-pin adapter on my car, and the lights worked. I gave him $20 and thanked him profusely for letting me have his adapter.
    It issue was probably just needing more current draw than the LEDs provided.
  18. redgt
    redgt Member
    Turning the parking lights on worked for my trailer with LED’s
    I found that work around by searching the forum
    Also have the Kurt adapter but haven’t tried it yet
  19. Rossy
    Rossy Member
    Hillsboro,Oregon
    I totally missed this, we were towing 3 years plus multiple u hauls. Did have one u haul with LED lights that didn’t work.
    Sooo today we were 90 minutes away from home at a small RV dealer picking up our new toy...and we’ll no trailer lights but the brake controller worked. Ordered a Curt 57003. There is also a Reese/Bergman 20142 lamp out bypass plug that should work. Bummer. So no toy until tomorrow.
  20. Rossy
    Rossy Member
    Hillsboro,Oregon
    Good question. The computer in a Volvo sends a pulse out periodically looking for a load. It won’t power up 12 v until it sees that load. Possibly to protect against a short. Once it powers up, if the bulb opens, it detects the loss of load and flags a warning. I’m assuming Tesla works similarly. I could hook up an oscilloscope to it tomorrow or probably in a week or so to determine what it’s doing.
