It didn't take long to lose confidence
Discussion in 'Model Y' started by Goldenco, Oct 7, 2020.
  1. Goldenco
    Goldenco Member
    Denver
    Well, my Y has 1,000 miles on it. When I went out to the garage, the left rear tire was flat flat. Since I haven't had a flat tire in about 40 years, I hadn't paid much attention to the tires when reading the manual. So I called the Roadside Assistance, assuming that a Tesla rep would drive up and fix the tire. After a while someone texted me and said they would have to tow me to the SC 17 miles away. Even once it is in the SC, who knows how long it would take to get it back. I looked in the manual and figured out there is no jack, wrench, or any other method to remove a tire. Fortunately I pumped the tire up and it is holding for now but since it lost a lot over the past day, I'm sure it will be flat tomorrow. I'll risk it and take it to a local tire repair place close by tomorrow. Hopefully they have wrenches to remove the odd sized nuts. Fortunately I have the pucks to put under the frame to protect the battery. Hopefully I can get it repaired by them.
    My point in all of this is I knew that buying a Tesla would have it's share of issues, but I never realized that getting a simple tire repaired would be this difficult. I have lost any confidence I had with Tesla and will not drive it any significant distance from home. Fortunately we have a second gas fired car that we have confidence in and can get it serviced anywhere.
    For sale soon - a low mileage Model Yw/one repaired tire.
    • Disagree x 38
    • Funny x 17
    • Love x 2
  2. Dennisis
    Dennisis Supporting Member
    Tucson
    Your loss.
    • Like x 9
    • Disagree x 5
  3. captanzuelo
    captanzuelo Member
    los angeles
    I feel your disappointment. I get the same feeling every time I get a flat on any of my vehicles. But the feeling goes away as soon as the tire is fixed. Probably just a nail, you can get plugged for under $20.
    • Like x 7
  4. Ssmtsx
    Ssmtsx Member
    Virginia
    This isn’t a Tesla specific problem. Many new cars do not come with spare tires anymore. If it makes you feel any better if you had purchased a new Prius instead of your model Y you would be in the same predicament when it comes to tire issues.
    • Like x 4
    • Disagree x 1
  5. captanzuelo
    captanzuelo Member
    los angeles
    I believe the prius comes with a 12v pump and sealant kit. I had to buy my own portable 12v pump and plug kit for the Y.
  6. Goldenco
    Goldenco Member
    Denver
    I understand, but I can't even get the tire off the car.
    • Funny x 2
  7. AKTech.it
    AKTech.it Member
    Texas
    OP - you can just carry a 12v tire inflator and tire plug kit for emergencies...no need to remove the tire(s). Also, just throw in the jack pucks ($20 on amazon) in the trunk for instances where the tire needs to be jacked.
    If you can't figure this much out...I guess you don't need to be buying a Tesla? Sorry - don't mean to be a jackass but it doesn't take much to remedy a small issue like this.
    • Like x 11
    • Disagree x 4
  8. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    While the Volt does not come with a spare, it does come with a compressor and slime kit. I purchased a similar kit for my Model 3 as it, along with a tire plug kit, will allow me to fix most flats. Quickly without the time waiting on a tow.
    • Like x 5
  9. Goldenco
    Goldenco Member
    Denver
    But I've never had a car come without a lug wrench and jack. It would be nice to take the tire only to a repair facility, particularly if it can't hold air.
    • Disagree x 1
  10. captanzuelo
    captanzuelo Member
    los angeles
    No worries, just drive up on a 2x4 or back up on a curb ledge to create some space. Access the puncture from behind.
  11. tccartier
    tccartier Supporting Member
    AZ.
    That's ridiculous Tesla has nothing to do with tires they don't make tires. maybe not even a tire manufacturer or problem how about just it was your turn to drive over a nail or some such thing. That's no reason to throw in the towel on the entire vehicle but I guess if that's what you choose to do it will be as another has said in this thread it's your loss.
    • Like x 4
    • Disagree x 4
  12. ElectricIAC
    ElectricIAC Devil’s Advocate
    DFW
    $40,000 cash. Small unmarked bills.
    Let’s do this.
    • Funny x 2
  13. brkaus
    brkaus Well-Known Member
    Austin, TX
    I don’t think Tesla has odd size tire lug nuts. Some do have plastic caps.
    • Like x 6
  14. mikeskuro
    mikeskuro Member
    Woodstock Vermont
    $39,999 is my offer! Large bills!
    Boards like this you’ll learn the accessories that don’t come with the car. They have much to learn and some good will type of accessories should be there, but they are not and they should be.
  15. steve841
    steve841 Active Member
    Ft. Lauderdale, FL
    Just like life in general.. if you don’t take the initiative to have what you need and learn to do it, then expect to be at the mercy of others.
    A plug kit and 10 minutes, I’m done.
    • Like x 8
  16. jmatero
    jmatero Member
    San Jose, CA, USA
  17. StanT
    StanT Member
    Fishkill
    Flat tires Stink! I will point out another car that doesn't have a spare... My Toyota Sienna AWD- yup, no spare (the AWD system takes up the spare space) but Toyota makes you use Run Flat tires. As the tire place said to me... "Yeah, run flat tires- none of the performance, half the millage, and twice the price." Which is SO TRUE! What really kills me is that Run Flat tires "can't" be repaired... so 1 nail and $400 later you are back on the road. And for some reason my car is a NAIL MAGNET and I've gone through 3 tires just in the last 1.5 years.
    So I'll take a car that I can fix the tires- In fact, I'm not replacing my tires ever again to Run Flat- I'm getting a spare from Modern Spare and going regular tires. And I've seen Tesla's up on the lift at my local Mavis, so I can say I feel pretty confident that I could get my tire fixed if I'm traveling.
    I'll also add that I did buy a slime kit and put a pump in my Tesla- but I've done that for every car I've owned.
    Sorry for your flat and good luck.
  18. JohnSnowNW
    JohnSnowNW Active Member
    Minnesota
    • Disagree x 2
    • Funny x 2
  19. Feathermerchan
    Feathermerchan Active Member
    Euless, Tx
    I always carry a compressor and plug kit in all my cars. We had a flat within a few days of getting my wife's Model Y. I was able to plug it and it's fine. I've only had two tires I can remember that I could not plug. The others have all worn out with the plug in them.
    Driving since 1972 when tires were far worse than today.
  20. S4WRXTTCS
    S4WRXTTCS Well-Known Member
    Snohomish, WA
    I agree that the Tesla should come with a tire repair kit at the very least, but this hardly something to sell a vehicle over.
    I would suggest practicing with a plug kit, and compressor since it's the ideal case of a slow leak.
