OMG you didn't charge it to 100% did you? This should give hot flashes to about half the residents here. Don't you know there's statistically significant chance that it might affect the battery in the non-TLC way?
When I get my M3 I’ll probably schedule charging to 80 or 90% daily. Can you please explain why charging to 100% and letting it sit for an amount of time would be an issue? Thanks.Just don't charge to 100 and let the car sit for multiple hours.
Would be so nice if our phones had the capability to set a charge maximum so we can still leave them on the charger all night and not have to worry about it. *sigh*To avoid degradation, it's best for theae types of batteries (including the one in your phone)
I think he might mean he wants to limit how much his phone charges to prevent battery degradation.Good news: They do! On the home screen select charging. On the charging screen you'll see the big graphic of the battery. The little triangle right under the battery is the charge limit. Just drag it back and forth to set the charge limit. There's no "set charge limit" button like in the car's UI.
Interestingly in the Leaf from 2014 model Nissan completely removed the ability to charge to a specific percentage. So when you plug it in, it can only stop after charging all the way to 100% (unless of course you remove the plug and interrupt the charging).
Either Nissan reserved an additional 1 or 2 kWh capacity more than normal so 100% is really only 95% or so, or, they simply didn't care about the degradation.
In the future all EVs will make the 90% as the new 100% for the end user. So you can set it to 100% everyday and charge it, but in reality it is stopping at 90% because of extra buffer.
Is charging regularly to 90 percent too much?
To explain further, if an EV had two charge settings (such as 80% for routine use and 100% for trip), the EPA said it would average the range of the two settings and that’s what could be advertised as the EPA rated range. This is one reason Tesla now has the slider, so there aren’t two settings for the EPA to average. The original firmware for the Model S had two settings, daily and trip, and daily was 92% or 93% as I recall.Nissan removed the ability to charge to 80% because it messed up their EPA ratings, that's it.
Ohhhhh. Haha yes that makes much more sense.
