It's Not a Bug. It's a Feature.
Discussion in 'Autopilot & Autonomous/FSD' started by NerdUno, Apr 4, 2019.
  1. NerdUno
    NerdUno Member
    Charleston, SC
  2. Tam
    Tam Well-Known Member
    Visalia, CA
    This feature can be very helpful if a good "hacker" would put some stickers on the road to make sure the car would steer away from and not slam right into a median concrete wall.
    • Informative x 2
    • Disagree x 2
  3. favo
    favo P3D+ owner
    Durham, NC
    This doesn't seem like that big a deal. They are using year-old firmware version (2018.6.1). Fooling auto-wipers with a big TV image--who cares? Controlling steering with a gamepad in the car--Tesla says they fixed relevant bugs in 2017 and 2018, also requires non-trivial physical access to car so it can be rooted, enabling the attacker to inject bogus data into the CAN bus. If you have physical access, lots of bad things can be done.
    Using the three stickers to fool the car into changing to a fake lane (supposedly going the "wrong" way) is slightly more worrying, except that they didn't demonstrate this on a real road, so there was no map data that might have helped the car figure out where the real lanes are and which way traffic flows. Also, this relied on the lack of other lane markings in close proximity to the bogus markings, limiting the attack scenario to intersections (and maybe poorly marked lanes) as they mentioned. Perhaps it would have still screwed up even with good map data or good surrounding lanes lines, but we don't know. Also, you aren't supposed to use AutoPilot in these scenarios yet, so user error. Plus, an alert driver would take over right away.
    As anecdotal "evidence," there is ongoing construction on a highway near me, where the lanes have been shifted, and there are lots of confusing, partially erased lane markings. In particular, there are three or four very clear old lane markings going diagonally across a lane next to a Jersey barrier. EAP has handled this every time I've gone through there (~20 times), except for the first time, 6+ months ago.
  4. 1375mlm
    1375mlm Member
    Texas, Houston
    I don’t think that car was on AP. First sign is it “drifting” gently. When AP recognizes a lane widening or narrowing, like when merging, it will close that gap quick. There’s no gradual drifting over to center for that. And ultrasonic sensors would have seen that coming way before, and stayed away from the divider.
    Seems quite clear the car was not on AP.
    • Disagree x 1
  5. MikeS1
    MikeS1 Member
    Calgary
    Autopilot was not on, Tesla I believe confirmed this and its quite obvious in the video it was not on.
    • Disagree x 1
  6. Tam
    Visalia, CA
    How about in a case that Tesla confirmed?
    What We Know About Last Week's Accident
    If hackers can do such a simple Autopilot redirection with stickers maybe the Apple Engineer didn't have to die.
  7. electronblue
    electronblue Active Member
    Earth
    Source?
    Because it sure looks like to me the car got confused by the diamond marking being the right lane marker and trying to cross between the left lane marker and diamond... thus ending up losing sight of the real right lane marker and then repositioning itself between the curb as the left lane marker and the actual left lane marker as the right lane marker... and then simply running out of space.
    Can be a coincidence of course but given the sticker hack looks like a very potential reason too.
  8. electronblue
    Earth
    #8 electronblue, Apr 5, 2019
    But with great sensor fusion such as Lidars or even perhaps more radars (side-facing etc) things like concrete barriers could be detected before vision gets there and thus could be avoided at all costs. Ultrasonics are not reliable at highway speeds...
    Tesla has a very limited sensor suite compared to what many others are developing outside of vision so Tesla is very reliant on being able to visually detect things — and obviously that part is still failing a lot of the time.
  9. favo
    favo P3D+ owner
    Durham, NC
    Not sure how that would have mattered in this case. They were not testing on a real road with curbs or barriers or traffic lights, etc. It looked like a runway or parking lot where they had painted some lines. What they showed was that if all you have to go on is some intermittent lanes lines, it's not that hard to fool it by adding your own misleading ones.
  10. electronblue
    Earth
    Yes but you never run into a concrete barrier if you can avoid it, lane lines be damned. A side-facing Lidar would have reliably seen the barrier and its distance. Perhaps side-facing radar too.
  11. favo
    favo P3D+ owner
    Durham, NC
    All of my comments were related to the Keen testing in the OP. I should also point out that article title was misleading, since there was not actually any traffic, oncoming or otherwise.
    Regarding the video of the grey Model 3 running sideswiping the barrier, I see no evidence they were on AP or even TACC. Original poster of that video said he thought the Tesla might have been trying to race a Chevy, and that both cars had been driving erratically for 15 minutes. Wouldn't be surprised if one or both drivers were impaired.
  12. emmz0r
    emmz0r Senior Software Engineer
    Norway
    Yeah I chuckled at this. I mean if you need to get into a car and open a bunch of panels, and root it no less, I would think it's easier to demonstrate dangerous situations by just pulling the steering wheel so you land in a ditch :p
