It's the Batteries, Stupid!
Discussion in 'Battery Discussion' started by vfx, May 15, 2008.
Tags:
  1. JRP3
    JRP3 Hyperactive Member
    Central New York
    This looks promising, and easy to implement:
    BBC NEWS | Science & Environment | Battery that 'charges in seconds'
    This would reduce unfounded lithium concerns even further as less would be required for each cell.
  2. Norbert
    Norbert TSLA will win
    San Francisco, CA
    This is another article giving different detail information:
    Lithium breakthrough could charge batteries in 10 seconds - Ars Technica
    "A battery that's sufficient to run an electric vehicle could be fully charged in five minutes—which would make electric vehicles incredibly practical—but doing so would pull 180kW, which is most certainly not practical."
    Perhaps the charging station could use a buffer battery which is charged more slowly, but then transmits its charge (maybe with lots of parallel connections) in a short time to the car battery?
  3. stopcrazypp
    stopcrazypp Well-Known Member
    180kW might be pushing it, but 60kW chargers are fairly common and have been used safely.
    Hyundai Santa Fe EV | GreenCar.com
    120kW Posicharge chargers have also been used (still works with a 240V connection):
    http://archive.electricdrive.org/index.php?tg=fileman&idx=get&inl=1&id=3&gr=Y&path=Workshops%2FFlorida+Workshop&file=Goldman.PDF
    http://www.pge.com/includes/docs/pdfs/shared/environment/pge/cleanair/ev4pt2.pdf
    Aerovironment has a one off 250kW charger but it isn't that common. This will probably require a 3 phase 480V connection, which might not be that common.
  4. Norbert
    San Francisco, CA
    #224 Norbert, Oct 14, 2009
    Interesting links! Such a high power charger would certainly be the best option, wherever it can be installed with the required connection to the grid. It seems they cost around $100,000.
    In many other cases, a buffer battery inside the charging station might solve a real problem. It could use cheaper batteries since there is no weight requirement, so hopefully it would cost "just" a few thousand bucks, and perhaps be leased to the smart grid when not needed.
    Even a charge station with just a 2 kW or 4kW connection, which can then "pre-charge" itself 24/7, could provide fast charges, definitely increasing the options of how it can be used. The capacity of the buffer battery could be larger than a single full charge, for increased use during "peak" times.
    This might make an EV practical where the available power connection(s) would otherwise not have enough (over-night) power for the intended range of use. Or for those who have better (but still not ideal) power connection(s) available, it would allow using more than just one full charge per day, since the charge station can re-charge itself when not used for charging a car (while you are driving).
  5. dpeilow
    dpeilow Moderator
    Winchester, UK
    We go around this one on a fairly regular basis - and in other threads. Please look back through the charging threads.
    There is no real problem. In locations where you might need an "EV service station" for fast charging, you are certainly going to have access to a 100-1000kVA supply. Furthermore, getting that supply brought in is going to be cheaper than setting up a normal gas station.
    Low and medium power chargers will be sufficient everywhere else.
  6. Norbert
    San Francisco, CA
    #226 Norbert, Oct 14, 2009
    Thanks for pointing it out, I had previously gone through several threads about charging but haven't seen any mentioning something like "buffer battery inside the charge station" yet, but will do a search tonight. I did see several threads dealing with the difficulties of having low power connections or 110 V only.
    If the new battery mentioned above will not degrade its quality when fast charging, I'm pretty sure I'd be interested in having such a buffer battery if it isn't expensive. For example, it would allow me to make a longer day trip, come home with an almost empty battery, fast charge, and go out for dinner. I'm probably lucky if in my apartment's parking lot I can get even 240V * 70A, I'd expect less.
  7. Serge
    Serge Member
    Queens, NY
    Bringing this thread back on topic :cool: this announcement was made back in March, but so far there were no additional [public] news or developments. There is an interesting link here, as Dr. Ceder mentioned in the article works in the same MIT department as Dr. Chiang, who happens to be A123's Founder. The chemistry discussed is lithium iron phosphate, which happens to be A123's chemistry of choice. Do they have something interesting coming soon?
  8. raymond
    raymond Member
    The Netherlands
    At home charging will be done overnight so 240V/30A is just fine.
    On-the-road charging can be done using virtually any amount of power. I used to work at a place where we had an electrically powered 12MW wind tunnel. This amount of power can charge 66 cars simultaneously at 180kW!
    How to get 180kW through a cable to your car -- that might be the tricky part.
  9. Norbert
    San Francisco, CA
    That's on page 12, "Wires and Cables". :)
    http://corridoreis.anl.gov/documents/docs/technical/APT_60861_EVS_TM_08_3.pdf
    "The electrical conductivity of QW is higher than that of copper at one-sixth the weight, and QW is twice as strong as steel. A grid made up of such transmission wires would have no line losses or resistance, because the electrons would be forced lengthwise through the tube and could not escape out at other angles."
    However, in 2006 it was "estimated that at least 5 years will be needed"...
  10. Norbert
    San Francisco, CA
    Another online article claimed that A123 is one of the two companies which licensed this. In an NPR interview, Prof. Ceder was skeptical that production could start sooner than in 5 years. ("5" years seems to be a magical number in everything EV).
  11. vfx
    vfx Well-Known Member
    CA CA
    Well that's better than "10 years away that Hydrogen is...
    Or is it? :smile:
  12. doug
    doug Administrator / Head Moderator
    SF Bay Area
  13. JRP3
    Central New York
    Oh crap, get ready for the FUD-slide :eek:
  14. Serge
    Serge Member
    Queens, NY
    We haven't yet discussed that Dow (a major U.S. chemical company) is moving into battery production "full steam ahead:"
    1. Received $161M loan from DOE to build a battery manufacturing plant in Michigan
    2. Acquired Kokam America's assets, makers of high capacity lithium polymer batteries licensed from Korea's Kokam Ltd.
    3. Also acquired lithium-manganese-nanophosphate technology from Swiss startup HPL (High Power Lithium).
    The latter is interesting, as HPL claims that on $/kWh basis technology has a 20% discount over lithium-iron-phosphate. What's also interesting is that according to this March 2009 presentation (last slide) Toyota has been working with HPL since 2003! The plot thickens ...
  15. dpeilow
    dpeilow Moderator
    Winchester, UK
  16. vfx
    CA CA
  17. dpeilow
    dpeilow Moderator
    Winchester, UK
  18. DaveD
    DaveD EVs Kick Gas!
    Redmond, WA
