It's the Batteries, Stupid!
JRP3
Hyperactive Member
Aug 20, 2007
19,432
42,585
Central New York
What they are describing sounds similar to what EESTOR is claiming. I wonder if EESTOR has actually already achieved this? This at least gives some credence to the possibility that EESTOR is for real.
Iz
EVs are here to stay
Nov 22, 2006
1,080
22
New York
See the Zenn interview under EEstor ultra-capacitors thread. I have my reservations regarding it's authenticity. If the interview is true we can put EEStor into the same category as ZAP.
stopcrazypp
9,862
4,797
Panasonic Develops High-Capacity Lithium-Ion Battery Cells that can Power Laptops and Electric Vehicles - Earth Times
New 3.4ah (mass produced 2012) and 4.0ah (mass produced 2013) 18650 cells in development by Panasonic. This answers my call for a ~2x improvement of density (which would roughly halve the weight of the current pack in the Roadster or double the energy for the same weight).
It seems the improvement estimate of 8% a year is fairly accurate. Starting with a 2.9ah baseline for 2009.
Year Actual Projected(8%/yr)
2009 2.9ah 2.9ah
2010 3.1ah 3.132ah
2012 3.4ah 3.653ah
2013 4.0ah 3.945ah
Hopefully, we see the same thing happen for automotive grade and other large format cells.
dpeilow
Moderator
May 23, 2008
9,151
888
Winchester, UK
While this is good news, I'd still sound a note of caution. We've been here before: DailyTech - Matsushita Readies New Battery Tech with 20-40% Greater Capacity (Where's my 3.6Ah cell? :mad: )
Anyway, if the 3.1Ah cell that just went into production is what gives the Model S a 300 mile range (do the maths), then 4Ah could up it to around 390 miles. What a shame they can't stick 8000 of these prototypes into a Model S and run off with the X Prize.
Is lightweight Li-Ion the right thing for stationary storage too?
For home use, I would think something heavier could be more cost effective and possibly have a longer calendar lifespan.
Exactly the same thought occurred to me on reading that. You'd think lead acid would be more cost effective (particularly some very large ship batteries that I heard about being thrown out too late recently :frown: ).
On the other hand, maybe this is where recycled Tesla batteries will end up. Or maybe there are distribution and storage costs (that the DIYer doesn't have to contend with) that mean the whole lifetime cost is better for these lighter modules if the market takes off.
vfx
14,790
40
CA CA
...On the other hand, maybe this is where recycled Tesla batteries will end up...f.
Some will make a business out of this.
Modify the Tesla battery box or a new box fit for the sheets out of Roadsters or Model S' that will sit below Solar panels or at the base of a Windmill storing power.
JRP3
Hyperactive Member
Aug 20, 2007
19,432
42,585
Central New York
Correction
I misinterpreted the data in the A123 cell testing PDF. The cycle chart showing over 100K cycles is not for the prismatic cells, it's for the 32113 cells, and it's only a shallow 10% cycle. Still impressive but not what I thought. I'll edit my posts to reflect the data.
Alfred
300
259
Zurich
New cells from Panasonic
2009 2.9ah 2.9ah
2010 3.1ah 3.132ah
2012 3.4ah 3.653ah
2013 4.0ah 3.945ah
Here is the original reference to the Panasonic press release:
Panasonic Develops High-Capacity Lithium-Ion Battery Cells That Can Power Laptops and Electric Vehicles | Headquarters News | Panasonic Global
Automotive use is clearly included. That will push the Roadsters range beyond 700km when replacing the battery in 5 years time.
dpeilow
Moderator
May 23, 2008
9,151
888
Winchester, UK
ABG has more on these new Panasonic batteries: Panasonic working on even higher capacity 18650 LiIon cells - Autoblog Green
The 4.0 Ah cell goes a different direction with a new silicon-based alloy for the electrode. The result is an energy density of 800 Wh/L compared to the 620 Wh/L of the current generation 2.9 Ah cells and a capacity increase from today's 10.4 Wh to 13.6 Wh. The downside is that the cell voltage drops from 3.6 V to 3.4 V and the mass increases from 44 to 54 g/cell.
And from the comments:
That's great that the energy density by volume will go up by 30%, but the probably more important energy density by mass is only going up by 7%. (236.4 vs 251.9 Wh/kg)
When compared to the 2.9Ah.
TEG
Teslafanatic
Aug 20, 2006
21,717
8,682
Perhaps that is the "advanced technology" cell that they have in mind for 300 mile range Model S?
