Joseph,
Martin's reply has been against using Ultracaps as in situ replacements for batteries. This is an entirely different argument than using them in addition to batteries. I'm not a crazy eestor fanatic or ultracaps save the world guy. They don't have the energy density to replace batteries, but they do have enough to store the amount of energy received by 5 seconds of regen due to braking at rates significantly higher than capable of by the ESS(which is limited to about 0.5C due to LiCo chemistry). They have enough to store ten seconds at 70kw which would be enough to cover almost all acceleration on the test gear track and would consequently increase battery range by increasing regen and decreasing high C discharge capacity losses.
Trust me, DC-DC boost buck power supplies aren't that difficult. The prius has one right now, and the Tesla already is utilizing a buck circuit for constant torque(V/Hz), so its more of an evolution than a redesign. He's right as to the large voltage change involved, but sizing the cap pack to 1.20 of rated energy storage(ie add another 10lbs of ultracaps) would make the voltage drop tolerable.
There are lots of reasons to have skipped a cap pack in the first iteration from a business standpoint. It is extra engineering work, and it does add weight and cost, and wouldn't increase distance for cars driven already with the intent to maximize range(which is to say, EPA numbers aren't going to change), but for a track car, and for real world driving where people actually utilize brakes it would make a huge difference. They also skipped V/Hz initially despite the fact that I don't think you can buy an inverter today that doesn't use that as its default operating mode. This doesn't mean that it was due to a technical problem with it, but rather was due to the constraints of producing an actual working car. I think arguments to authority miss the point, which is that there are numerous reasons for leaving this stuff out other than technical feasibility. Hopefully now that their EEs aren't putting out fires in simply making the Tesla work, they have time to optimize the existing drive train.
Which brings me back to my original statement that the easiest way to double track range(test gear style track) would be to swap to 2900mah cells and include a cap pack to capture regen. Of course, they still need better thermal management of the motor, but that's another issue entirely.
Tim
