I've already got a J1772 30-amp 240v wall charger (for my Leaf) ...
Discussion in 'Model S: Battery & Charging' started by eco5280, Oct 11, 2014.
  1. eco5280
    eco5280 Member
    Country
    I'm replacing my Nissan Leaf lease with a Model S. I've already got a 30 amp 240v J1772 charger on my wall. Can I just use the little adapter they give you in the Tesla trunk kit and charge the Model S with this EVSE? I'm getting about 6.6 kWh per hour charge on the Leaf. Would I get the same on the Tesla or do they throttle it down? I'm not sure if I'm going to go with the Supercharger option if that matters for this discussion. Thanks!
  2. Lloyd
    Lloyd Well-Known Member
    San Luis Obispo, CA
    Yes you will get the maximum output of the EVSE.
    Get the supercharger option, you won't regret it. You'll get it back at resale!
  3. Canuck
    Canuck Well-Known Member
    South Surrey, BC
    It will work but the one that comes with the car is 40 amps and it also has a button that pops open the charging door. I'd recommend you install an outlet and keep the current one as a backup.
  4. Bifff67
    Bifff67 Member
    Northern Virginia
    Definitely go with the Supercharger. Adapter will work fine. But Wonder what wire they ran for your charger and if you can upgrade to a 40 amp wall plug, like a 14-50 or an increase on your current box. "Overnight" for an empty 85 is 8 hours at 40 amps but 12 hours for 30 amps. Still, will work fine since car is rarely empty. Run with it as it is for a while, and then decide if change is needed.
  5. eco5280
    eco5280 Member
    Country
    I hired the electrician and bought the cable myself - I put in a 40 amp breaker and ran 8/2 NM wire (8 gauge) so theoretically I could upgrade the wall connector at some point, but so long as the Tesla will charge at 6 kWh per hour, that's 100 miles in 3 hours and plenty for me. Like you said, with a 60 kWh battery pack it won't be running on empty when I plug her in at night anyhow.
  6. Vger
    Vger Active Member
    Salt Spring Island, BC, Canada
    You will not quite get 100 miles in 3 hours. It takes 40A to get about 85 miles in 3 hours, with a strong 240-250V circuit. You will get closer to 60-65 miles in 3 hours.
  7. eco5280
    eco5280 Member
    Country
    Thank you yes you're correct. I meant 4 hours. But it's neither here nor there, I don't drive anywhere near that much in an average day, I work from home. Once in a while we drive about 60 miles up to Boulder or something so that would be a 120+ miles day, but that's rare. Sounds like I will do fine with my current EVSE for now. Thanks all! Very helpful.
  8. DavidM
    DavidM P2624, Delivered
    Florida
    I have a 40A capable outlet, but ever since Tesla changed the software, I have been charging at 30A. I'm still full before I go to bed most evenings, so it doesn't matter. We have two heat pumps for AC, an electric oven, electric dryer, sub panel, etc. All on a 200A service panel. Next house we'll have a 300A or 400A service.
  9. jcaspar
    jcaspar Member
    Sacramento
    The Leaf charger will work great. More than you will need for overnight charging. I would get a second J1772 adapter to keep with the car so you will always have one.
  10. Bighorn
    Bighorn Top Supercharger
    Big Horn, Wyoming
    I agree it should work great. The only thing is you won't be using the UMC cord that has the button to pop the charger port. Lolachampcar makes a fob that will pop the charge port door for little money--you might like that convenience.
  11. eco5280
    eco5280 Member
    Country
    That's a great tip, thanks. For $20 that is probably a good convenience.
  12. N4HHE
    N4HHE Member
    Madison, AL
    I really think you should not only spring for the Supercharger option but the 85 kWh battery which includes Supercharging. While the 60 will navigate most Supercharger routes it appears some are marginal. But also keep in mind eventually the battery capacity will fall from wear. The deeper you cycle the battery the more wear per kWh used so an 85 should wear less than a 60 if your daily use is only 40 miles because the percentage discharge/charge is less. And when the battery does wear it has 25 kWh "more available tread" before it reaches the same level and has to be replaced.
    Supercharging is essential for road trips. The ability to make road trips is what separates a Model S from wussy city cars. A 30 minute charge every 3 hours is trivially less convenient than a gas stop every 400 miles in my Prius. Or at least "it will be" when when Nashville and Louisville go live. Prius is gone. Nashville and Louisville haven't even selected a site. Clearly it will be Elon's fault when I am forced to burn 38 gallons of diesel in my SUV to make the trip. :smile:
    When "nicely equipped" was $84k another $10k for 85 kWh was a relatively easy upgrade.
