I've Lost my Effing Key!
Discussion in 'Australia & New Zealand' started by LimoX, Jul 10, 2017.
  1. LimoX
    LimoX Member
    Camperdown
    It's a little sad that this is my first thread I've opened. But for the life of me I cannot find my bloody key! I have torn this car upside down, it's somewhere on board but I cannot find it.
    I've had to leave it basically active on three occasions where somebody could've just walked in and driven off with it!
    Are there Any really really strange places that keys have lodged?
    Signed
    Now Hairless
  2. purplewalt
    purplewalt Active Member
    Dallas, Texas
    You might try looking between the seat and the door sill.
    The key being black makes it hard(er) to visually see.
    Happened to me, so I also got a small enclosure for the key so it would not slip out of my pants.
  3. HabitualUser
    HabitualUser Member
    Los Angeles
    Just check the exact place you lost it. Case solved.
  4. OzSimon
    OzSimon Member
    Gold Coast Australia
    Did you look under the phone charging spot in that secret compartment?
  5. Dborn
    Dborn Confirmed
    Sydney, Australia
    Between the seat and the center console. Move the seats as far forward as you can to check and use a torch.
  6. JHWJR
    JHWJR Member
    Pittsburgh PA
    Mine fell out of my pants and lodged in the little well that is created by the carpet pieces around the post that supports the second row seats in my Model X. Since then, I've tried to put the key in the little pocket in the door near the window. And for good measure, i have added a "Tile," that I can make beep with my phone. (Tiles are great ideas for LOTS of things once you're tired of searching for stuff.) Good luck.
    I think Dborns' suggestion that is it against the track that supports the driver's seat is the strongest, but that seems so obvious. Move the seat forward and use a bright light is key, though, no pun intended.
  7. Duke-U
    Duke-U Member
    Tilburg, Netherlands
    If you lay it down on the closed phone dock and you accidentally opened it, the key will roll down into the space under the phone dock. Fishing it out there provided me with some coins, a napkin and some odd bits.
  8. animorph
    animorph Active Member
    Scottsdale, AZ
  9. LimoX
    LimoX Member
    Camperdown
    Great help guys! Got home late after a long day so pathetically announced to my wife my predicament. She's always up for a victory over me. Took her 10 mins but she found it in a place I had looked repeatedly..... under the lower armrest/centre console thingimajig.
    Told her that's another reason why I married someone 10yrs younger.
  10. Dborn
    Dborn Confirmed
    Sydney, Australia
    In the cup holders there?
  11. LimoX
    LimoX Member
    Camperdown
    No, way further back under that little shelf In front of the ciggy lighter. Designed for those needing to stash Nimbin's finest product.
  12. Kirriport
    Kirriport Member
    Australia
    My key never leaves my pocket. Why would you put it in the car somewhere?
    There must be a good reason for doing so at times, but I've never had to resort to it.
  13. LimoX
    LimoX Member
    Camperdown
    #13 LimoX, Jul 11, 2017
    I'm often in and out of the car loading and unloading luggage for customers. It's happened more than once to me when leaning up against the rear bar reaching into the cargo area for a bag up against the rear seat, "BEEP"! Goes the descending door warning.
    I have about half a second where I lose my whole professional demeanour dashing around to the side of the X where the Falcon Wing door is about to do the most damage. (Yes they do give you a fair hit in the head before coming to a stop)
  14. OzSimon
    OzSimon Member
    Me too, I have closed doors on people several times so now the fob is left inside the car 24/7 except when out in public.
    Has no effect on vampire drain, I am finding I loose 1 klm per night.
  15. baillies
    baillies Member
    Sydney, Australia
    Where exactly on the Gold Coast are you? I would love to take a test drive!:):):)
    • Funny x 2
  16. BenT
    BenT Member
    Adelaide, SA, Australia
    Dear Hairless.
    Hopefully by now you have found your key. You can of course lock the car via your phone app even if the key is in the car thus stopping someone simply driving off with the car.
    If the key is still in the car, has the battery died yet? There are quite a few posts about batteries being exhausted by being left too close to the car.
