The J1772 adapter should be locked to the car with the car is locked. I am pretty sure that the J1772 can be disconnected from the adapter, but nothing terrible will happen if it disconnected under load. The contacts may just wear out a few cycles earlier.
It's mechanically locked in the port. Sounds like an electromagnetic actuator, though...:wink:
According to the LA service center there were some early J1772 adapters that are actually slightly too large. If you find it difficult to insert the connector into the S and it requires too much force they will replace it with a correctly sized one.
Mea culpa. My apologies.
Okay, really simple question: do the J1772 chargers communicate to the car how much current they are able to provide, or do I need to explicitly set that up on the touch screen.
They communicate. No worries.Okay, really simple question: do the J1772 chargers communicate to the car how much current they are able to provide, or do I need to explicitly set that up on the touch screen.
In a lot of the videos, there is an audible "clunk" when locking and unlocking the charge port (at least that's what I think I'm seeing/hearing). Is the adapter (and UMC) held in by a mechanical latching device, or is it electromagnetic? Just curious.
With the J1772, yes. With other adapters, no. For instance if you used a NEMA14-50 adapter on a socket that you knew had only a 30AMP breaker, or was on a shared circuit with another load, then you would need to manually turn down the current level.
I think what you are hearing is the contactor in the charging station closing whem the cable is attached and the car is ready to accept a charge. It is a large contactor so it makes a noticable noise.
Hi Steve,
No problem.
Its sort of ironic that in the vast majority of cases when using an HPWC where the charging cable can be secured, it will be in someone's locked garage where someone disconnecting the charging cable is not an issue. Whereas in public charging situations where someone disconnecting the charging cable could be an issue, the cable can be disconnected. :wink:
Fortunately, at least the expensive adapter is still locked to the car in public charging situations.
Larry
