Kevin Sharpe
we have tried repeatedly to encourage recargo to share data but they show little interest in a free and open database....Perhaps the two could share data?
Since you have *NOT* recently had the firmware upgraded after ordering Tesla's adapter cable ... I am surprised it charged at all. I would expect either A] the Roadster to see the pilot signal (which should be 30A) and respect that; or B] not charge and trip the VDS (not the breaker) with an error. I am aware of non-updated 1.5 Roadsters (like yours) that do either A] or B] depending on the EVSE vendor. In the case of B] a firmware update resolved the issue. Your specific case/circumstances is a new one. Let Tesla know ... I am sure it will start with a firmware update to debug the issue, but the case may be new to them too.General Electric has introduced their version of a Level 2 charging station - Electric Vehicle Equipment from GE.
I attended the rollout at their factory in Mebane, NC last month, and plugged my Roadster ('08, VIN 244) with the 1772 adapter cable into the station they had installed in front of their factory.
The first time, it tripped the breaker: the car had remained programmed to 70A.
I reset the car to 30A, and reset the breaker - it tripped again (perhaps the breaker was hot?).
I reset the car to 24A and it charged satisfactorily.
My firmware is over a year old, and I suspect I need an update to properly read the pilot.
I just tried to charge at a Shorepoint charging station. ... Has anyone successfully charged a Roadster on a Shorepoint system?
Shorepower WU-120 ... Shorepower's units are unique in that they take 240 volt input, but provide four Level 1 outputs, handling four EVs at once.
ePump stations from Shorepower Technologies combine the latest electric vehicle charging technology with unparalleled customization options for municipalities, private employers, retail environments and fleet locations
More info about Shorepower "ePump" tower
I wonder if these work?
...The other owner and I have been talking to the Shorepower folks, but we haven't figured out what the problem is yet.
Other owner = Daniel?
Didn't he say that the Pilot Signal has unusual voltage levels?
Very few commercial J1772 EVSEs pass proper +12/-12 volt control pilot signal. Since there is a required GFCI test, that is considered sufficient for UL listing. There was a problem with the Shorepower units only putting out +11.5 volts on the control pilot pin, but this was fixed on all the Portland units at least.I am the other owner Tom was referring to. I put an O-Scope on the pilot signal and discovered that the Shorepower Stations (in Spokane at least) only swing the pilot signal from 0 to +12V. The -12V swing is not there!!! Since the -12V swing is really the integral part of the safety system, I'm not quite sure how they pass UL without it.
