Thanks.It seems either our team got the design validation work wrong, or Tesla has changed their software! I owe Klaus several apologies, apparently...
Previously I observed that (when the owner is in range) that a stopping of charging OR a press on the 'charge port' button would unlock the charge port, along with the J1772 button. Now, I can validate what Klaus saw: a CapturePro-locked J1772 device can ONLY be removed if you press the handle button and NOT when the charger stops or when the button is pressed. I intend to get in touch with the engineering group and try to find our why (if?) this behaviour has changed.
My opinion is that the charging lock pin should retract when any of the following happens: internal button, external charger stops, or the J1772 'stop' signal is actuated via the handle button + owner in range
More circumspect comment: why does the charge port EVER lock when the owner is in range? Should only lock when the owner leaves the area, seems to me.
Now I have to update the website and send out alerts to all customers -- that's not cool.
For all customers: UNTIL I CAN VALIDATE THE ISSUE AND FIND ANOTHER WAY TO UNLOCK, PLEASE DO NOT USE THE CAPTUREPRO. My apologies for the inconvenience. I'll send out an email alert tonight to all known customers.
I'll try to be brief:
I tried to "open charge port" on the Tesla charging screen. Did not release the adapter.
I tried to restart charging on the Tesla screen. All buttons were greyed out and inactive. Charging was stopped, so there was no active option to stop it or start it.
I tried to increase the charging limit including range charge, to restart charging. None of these functions were active.
I did not try to push a button on the ChargePoint terminal. There are indicator lights below the LCD display, and if any of them are also buttons it was not obvious to me. I'll try next time I'm there.
In my experience, "open charge port" is not the same as unlocking the charge port. The former makes low volume higher frequency clicks, versus the lower frequency stronger knocking sound of latching or releasing the charger in the Tesla charge port. I cannot find a function on the Tesla screen to unlock the charger, but I hadn't really looked for it until I needed it yesterday. I have to push the button on the UMC or the J1772 to get the port to unlock. This has nothing to do with opening the door.
In the morning when I get to the car, I usually open the rear hatch door, put my bag in and close the hatch, after which the car is unlocked. That wakes up the car so the charge port is lit green. In order to remove the UMC, I have to push the UMC button, sometimes twice, otherwise I can't remove it. This and all of the above is obviously with my key fob in my pocket.
I am positive that it was not just "sticking" and hard to remove. I have figured out the difference between the two in the month that I've had the car. I tried with all my strength to pull it out (without breaking it by angling or torquing it) and it wouldn't budge.
I agree that with the key fob near the car one should be able to remove any charger, provided that the charging has stopped. One should not be able to cut 30+ A at 240+ V by pulling out a plug, but while inactive it should be unlocked in that situation. However, with the key fob absent it should stay locked, otherwise anyone could cut the power to the charge terminal and then steal the adapter.
Finally, none of this is intended as a criticism of the Power12 CapturePro device. I posted and emailed Babylonfive to tell my story and to ask for assistance, advice and others' experiences. I like the product and I intend to use it once we figure out how to do that reliably with my car as designed. I get the feeling that I surprised Babylonfive with the post appearing publicly, and I apologize to him for not letting him know about that privately first. From his replies I can see that he is taking my mishap very seriously, and I appreciate that! I will do my part in figuring out how to fix the issue, as best as I can and as my time permits!
Thank you!
While I appreciate the idea of trying to be fair to your customers and wanting to do all you can to avoid anyone else getting in a situation where the device is stuck, IMO I think you're jumping the gun here with advice to destroy the device and delivering refunds.
Tesla may, very well, change the software to again allow for a very simple release in a near-future software update. Furthermore, while some customers may feel disgruntled and unfairly treated, I am not among them. You developed an ingenious product that worked as designed and there's no way you could have predicted a software change like this. Also, I think it is likely that Tesla will be forced to have some sort of manual release option in case of malfunction of the J1772 or a Tesla plug so the owner can do an 'emergency' release.
I know this has to be hugely deflating for you, but my unofficial advice to everyone is to not destroy your charger lock, but stop using it and wait patiently for Tesla to get their act together...I think it likely they'll make things right.
David, why not just create a means on your site to allow people to request a refund if they want one. Mine, you can keep.
Can't the "stop charging", then "unlock charging port" function from the app allow you to disconnect the whole mess from the car, then slightly bend the plastic to get it loose?
David is doing exactly what he should with regard to the recall. (Apart from stopping by your house and personally picking it up. Tesla spoiled us all...).
If you don't destroy it, some family member 6 months from now may stumble upon it in the glove box, not know about the recall and use it, and as a result end up missing an international flight. That could set David up for quite a liability lawsuit.
It's a sad situation overall. I sent a mail to ownership regarding this - I recommend you do the same.
That method has always worked for me, too, on 4.5. I've had issues where it didn't immediately unlock and I had to resume charging, and reunlock and such, but was always able to get it off after a couple of tries. Just figured that was normal.Not your fault-don't feel the need to refund my payment. You could not have anticipated this issue. FWIW I am on v.4.4 and the only way I can unlock with the CapturePro on tight (as designed) is to end charging at the ChargePoint station, then go to the touchscreen Controls and hit the charge port button (even though it shows the open port). This unlocks the adapter and I can remove the adapter, then pull off the CapturePro and disconnect the adapter. Indeed if I 'improperly' used too big a slot on the CapturePro to allow the button to be pushed on the charger handle, charging would stop and then you might in fact be able to disconnect the whole setup.
Don't despair. Thanks for your efforts. See you in a couple of weeks @ Teslive.
Nope. The app acts like the in-car screen. It stops charging, but doesn't unlock.
