Problem #1 - When I connect a J1772 EVSE, the vehicle negotiates properly with the EVSE to determine the max current that can be delivered. But it will not ramp up past 0A. Multiple EVSE's, multiple adapters, multiple locations. The only common factor here is the car (Model 3).
Problem #2 - I'm having a hard time getting the max charging rate value to "stick". At home, I found early on that I'll hit an EVSE fault if I charge @ 32A, but 30A works just fine. After one of the recent updates (might've been a pre-V10 update), that setting got cleared, and suddenly I saw that it was showing a different max (can't recall if it was 48A or 32A). I've tried a variety of different things, but I haven't been able to get this to "stick". I set it in the UI to 30A. Then I connect the EVSE & the car then sets the max value to the max negotiated with the EVSE (32A). There are 2 numbers displayed in that UI - one in grey that's the max capability of the EVSE, then the one above it in bold which is the max charging rate I want to use. It's this bold number that is changing even though I'm setting it to something else. I was able to get it to stick on one car, but can't make it happen on a second one (in this case, the second one is a loaner S). Is there some magical series of steps I have to follow? Seems like it's harder than it should be
