I could use one tomorrow morning - anyone have one I can borrow? If I get another plug-in this could be very useful on a daily basis at which point I'd build one.Not sure how many people actually need something like this
I was at the LEAF meeting where the Hydra was presented. I was impressed with the level of careful consideration the designer gave to all of the possible usage scenarios. Not sure how many people actually need something like this, but if you do, it seems like he is trying to do it right.
I still haven't seen an answer to the Model S question: will the MS adjust it's charging current if the pilot changes mid charge?
The LEAF and I think the Roadster (may have been finally fixed) fail to charge with an 80a pilot, so a lot of CS-100s, when installed as public chargers, end up @ 70a.
I could see this as a very nice addition to the house/garage with limited total power and two Teslas. Putting the Hydra on the output of a HPWC with a Tesla connector on one output of the Hydra and a J1772 on the other Hydra output, with the Hydra in "share" mode would be pretty sweet. Plug both Teslas in and each gets half power. Need to charge one quickly, then all you have to do is unplug the other one.
It has always adjusted it's current down as far as I know, and know we know that on firmware 5.9 it will adjust back up as well.I still haven't seen an answer to the Model S question: will the MS adjust it's charging current if the pilot changes mid charge?
This is basically turning the Hydra into the equivalent of the Chargepoint CT4000 except using OpenEVSE guts, no?I don't know if anyone is interested, but I have a design for a Hydra board that replaces the inlet handling circuitry with a GFI. The idea is that with a GFI, one could replace the J1772 inlet with just a power cable, making the Hydra a straight-up two-headed EVSE (no host EVSE required).
Since I've sold a grand total of two Hydra boards so far, would this alternative configuration make anyone more likely to want to build one for themselves?
Yes, although the guts aren't OpenEVSE. They're my own open-hardware design, though I will admit that they are heavily "inspired" by OpenEVSE.
I think we should team up on this one... OpenEVSE with a second port - HYDRA with GFCI. I think the resulting design would be the same by taking either angle.
I'm curious why you would put a GFI on the inlet side of the Hydra. This doesn't seem like a logical place for it. If the Hydra has been modified so it no longer needs a host EVSE, then it has to have it's own contactor. Why wouldn't you put the GFI downstream of the contactor where it's normally installed in an EVSE? You really should have a separate GFI sense on each branch.
@nsayer, how much would you charge for a fully built Hydra dual EVSE that connects directly to a 50A breaker? I know someone who's getting a second EV and has no more space in their panel for a circuit for a second EVSE.
Bummer. Thanks for answering.I have resisted selling complete units because I don't have the kind of product liability insurance or UL approval such a product as a complete product needs.
I was thinking it would be a nice product and could actually help w/the EV charging situation at my work. It's not at all bad right now due to EV/PHEV drivers observing good etiquette, an internal list of EVs/PHEVs (w/license plates, owner names, etc.) + EV valets.
However, a tethered J1772 Hydra (so it doesn't get stolen) would be actually quite nice... We have numerous cars charging w/only 3.x kW OBCs or less (e.g '11 - '12 Leafs, Volts, Plug-in Prius, Ford PHEVs, etc.), so this wouldn't slow them down much/at all. Our Chargepoint EVSEs have 30 amp output max.
I would love to hear if you think this would work.
My idea is to connect the input of the Hydra to the output of an HPWC, using cable rated to 100 Amps. I would then connect one output with a 100 Amp contactor to the original HPWC MS cable, and the other output through a 100 Amp contactor to a 75 Amp J1772 cable/connector that I have. This would allow me to charge my MS as well as my Roadster from the HPWC. Is there a way to allow the MS connector side to be limited to 80 Amps and the J1772 side to 75 Amps when there is only one connector used. When both outputs are used, I would want the 80 Amps in to be shared, giving each output 40 Amps.
If you think that this will work, I will probably buy one of your controller cards and start acquiring the rest of the parts. If it works, this will be a nice add on to a Tesla HPWC to support Roadsters and other J1772 compatible EVs.
