Jack Points
Discussion in 'Model 3' started by Tam, Nov 24, 2017.
Tags:
  1. Tam
    Tam Well-Known Member
    Visalia, CA
    Model S and X have rectangular lifting pads with 3 holes and they are located on the outer edge.
    Model 3 Jack Points look different (triangular with 1 hole?) and they are not located anywhere near the outer edge but rather more inward.
    Would anyone please take a picture because the drawing is too 2 dimensional.
  2. Murphy’s Law
    Austin Texas
    D9394752-8431-4D0D-A549-4EF2B8E4DECA.jpeg C4A5A1A5-6B77-4547-981B-58A13363CCCF.jpeg 9B616366-CCEC-41C6-8FB1-A0A0650468CC.jpeg 1F5B55E5-DEB9-4754-BC16-49BB4046293B.jpeg [here yah go, yes the 3 has a completely different jack point area, no clue why they couldn’t just stay constant but yah it took me a while to design a jack pad adapter for the 3.
    Available next week.
    QUOTE="Tam, post: 2428475, member: 11118"]Model S and X have rectangular lifting pads with 3 holes and they are located on the outer edge.
    [​IMG][/QUOTE]
  3. Murphy’s Law
    Austin Texas
  4. PoitNarf
    PoitNarf My dog's breath smells like dog food
    NJ
  5. Murphy’s Law
    Austin Texas
    $50-~+ more than likely
  6. PoitNarf
    NJ
    I’ll definitely take one!
  7. Garlan Garner
    Garlan Garner Supporting Member
    Chicagoland
  8. Oil4AsphaultOnly
    Oil4AsphaultOnly Active Member
    Arcadia, CA
  9. lairdb
    lairdb Member
    #10 lairdb, Jun 19, 2018
    These look pretty simple to model -- if you know the measurements you want.
    Here's a magnet retention style:
    Here's an o-ring retention style:
    Need:
    - 3 dimensions for the rectangular part
    - diameter and height for the round part
    - diameter and thickness for the magnet, or cs and id on the o-ring and height to centerline of o-ring
  10. miimura
    miimura Active Member
    Los Altos, CA
    Most 3D printers will not make a solid part, they make a honeycomb or other pattern of ribs inside solid sections of the part. This is likely not strong enough to support a car. Now, if you wanted to make a 3D printed shell to put over a steel or aluminum plate, that would work. The "pin" portion could also be 3D printed because it's not supporting any real load, it's just locating the pad on the car.
    I purchased the Reverse Logic jack pad for our 3. It looks very high quality and is machined from solid Delrin bar stock. I haven't tried it yet though.
    • Disagree x 1
  11. lairdb
    lairdb Member
    Just depends how you set the fill settings when preparing the model for printing. The product linked above on EBay is clearly FDM-printed.
    This image (stolen from this article) shows infill settings of 20%, 50% and 75% in FDM printing:
  12. Garlan Garner
    Chicagoland
    The current version of this product is definitely made on a filament fed 3D printer. Just look at the lines.
    I have a 3D SLA printer which is tremendously more accurate and can print stronger repeatable designs.
    I'll post some of my creations when I get my Model 3.
  13. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    I'd really like to know WTF Tesla couldn't make all three cars the same. It's like they were made by three companies. Or one was a bad (you know what I mean) copy. How could the X's jack points not be the same as the S's. Then the 3's are totally different.
    What if you own all three cars... you need three sets of these? Man....
    I have a set of these for my X, and the vendor (Murphy's) worked with me to get the magnets to work, properly in a second revision and I love them. Great way to get people that aren't experienced with lifting the cars to not make a mistake. Experienced people could use hockey pucks, but these are easier. (No relation except satisfied customer!).
  14. JC_FTW
    JC_FTW Member
    North Texas
    Excuse my ignorance please but what are these for? Do you keep in trunk for when you need them or do they mount and you drive around with them?
  15. Garlan Garner
    Chicagoland
    You keep one or 2 in the trunk in case you need them.
  16. Runt8
    Runt8 Active Member
    Colorado
    Does anyone have links to low profile jacks or jack stands that work with these?
  17. RMGumina
    RMGumina Member
    NJ
    I have been told any low profile jack with a 3 ton capacity should be fine... Home Depot has a few.
  18. miimura
    Los Altos, CA
    Stands are more of a problem because you have to jack and support from the same place. I know of two solutions.
    RennStand
    Jackpoint Jackstands
  19. thesteve
    thesteve Member
    Toronto, canada
    Will Costco tire mess up the jack mount placement? I've seen some mashed up mounts from people taking delivery with damage. Any way to ensure tire shop lifts the car properly?
