Hi everyone!
I'm excited to soon be the new owner of a previously-loved 2015 P85DL from my neighbour (who's buying a new P100DL). I've already bought a set of pre-owned black 21" Arachnid wheels that I'd like to install myself after getting the car. I've swapped wheels on my ICE cars plenty of times, but understand some extra caution is needed to protect the battery.
Tools I Already Have -- Torque Wrench, Impact Wrench, Floor Jack
I already have a good torque wrench (for 129 lb/ft) and impact wrench that should do the trick. I also have a 2-ton low-profile floor jack lift that I've used with my ICE cars. I understand that the Model S is a heavy beast at 2142 kg / 4722 lbs / 2.36 tons. If I had to lift the entire car with my jack at once then it wouldn't be sufficient; however, since I'd only lift one corner of the car at a time to swap the wheels, would this be OK?
Jack Lift Point Pads
I've already purchased a set of these DEWHEL Jack Lift Point Pad Adapters from Amazon for $78 CAD that arrived this morning. The description says that they're for the Model 3; however, the product number is the exact same as the one for the Model S sold on the US Amazon site, so hopefully they'll work fine. I don't have the car yet to test them -- has anyone else tried these?
Socket
From what I've read in these forums, it sounds like I'll need a thin-wall 21MM socket. Does anyone have any recommendations? I was thinking of ordering the CASOMAN 1/2- Inch Drive Wheel Protector Impact Socket Set from Amazon for $30 CAD. Does anyone have any experience with this set or recommend another socket set?
Lug Nuts
Should I buy new lug nuts for the black Arachnid wheels? Or do people just put caps on the existing nuts? Any recommendations?
Wheel Paint Touchups
There's some curb rash on the black arachnids that I bought -- is there something that I could use to disguise it a little? Perhaps some kind of touch-up paint? Or maybe even a black sharpie marker?
Anything Else?
Are there any other tools or accessories that I should buy before swapping the wheels? Is there anything else that I should know that I've missed?
Thanks!
Socket
Lug Nuts
Anything Else?
Thanks!
