This is cool and all, but literally 10x over my budget for jacks/standsQuickjacks are awesome. Should of bought them years ago... View attachment 327960
It's easier to just use a 3.5" clearance floor jack and a low profile adapter. For example this Home has this option. Also I understand that these are thin enough, too: Vendor - Model 3 jack pad adapter tire service tool Although cheaper, the later is not the full solution of course.Several threads about the jack points on this car and the adapters to use them. The model 3 only has about 5.5" of clearance below the jackpoints WITHOUT an adapter. Has anyone looked into jacking the vehicle by the suspension? Lower A arm knuckle or somewhere? Just curious if we could get it jacked up via suspension then slip in a traditional jack stand under the jack point?
I'm not looking to get under while jacked via suspension....I have conventional jackstands and want to jack up by suspension and lower jackpoint onto jackstand....It's easier to just use a 3.5" clearance floor jack and a low profile adapter. For example this Home has this option. Also I understand that these are thin enough, too: Vendor - Model 3 jack pad adapter tire service tool Although cheaper, the later is not the full solution of course.
I'm not sure I'd go around trying to get in under and lift on the suspension or such. That is a recipe for a Bad Day somewhere down the line.
The suspension can't lift wheels.I'm not looking to get under while jacked via suspension....I have conventional jackstands and want to jack up by suspension and lower jackpoint onto jackstand....
I have the 5000 SLX and the rubber risers (come with the kit) covers the holes on both ends just barely. I’m planning to make some custom wood plates to provide a level plane so I feel more comfortable jacking the car up. I’ll get about 1/2” more distance to work with. I’ve got my wife’s Honda Pilot where this will come in handy also. If you are in the market for this I’d get the EXT version to make it easier to align the holes to the Quickjack.
The issue isn't about getting underneath. Well they are a ways underneath to reach to making it harder to line up and all, but I'm talking about the futzing around jacking on parts that weren't intended for that use, going back and forth (you'll need to switch back and forth to get it under and then again to get it out) and overall greatly increase the likelihood something will slip and damage the vehicle's undercarriage. Damage that will almost certainly Tesla wouldn't cover under warrantee.I'm not looking to get under while jacked via suspension....I have conventional jackstands and want to jack up by suspension and lower jackpoint onto jackstand....
Another member posted 58.75" (as I recall) between the middle of the holes. Go with the EXT and be a happy person..Hi, I actually asked this in another thread, how far away are the jackpoints? So the SLX is JUST ok, but you'd suggest the EXT?
Thanks!
My measurements were:Hi, I actually asked this in another thread, how far away are the jackpoints? So the SLX is JUST ok, but you'd suggest the EXT?
Thanks!
So, I believe this "futzing" was the details that I started this thread looking for... Has anyone found a good spot that would allow me to avoid futzing and cleanly, predictably, and safely lift via suspension.The issue isn't about getting underneath. Well they are a ways underneath to reach to making it harder to line up and all, but I'm talking about the futzing around jacking on parts that weren't intended for that use, going back and forth (you'll need to switch back and forth to get it under and then again to get it out) and overall greatly increase the likelihood something will slip and damage the vehicle's undercarriage. Damage that will almost certainly Tesla wouldn't cover under warrantee.
The Answer being "No, ill advised to do that."So, I believe this "futzing" was the details that I started this thread looking for... Has anyone found a good spot that would allow me to avoid futzing and cleanly, predictably, and safely lift via suspension.
<sigh>
If you look into jack/stand combo sets meant for putting cars with limited lift points on stands I think you will be surprised how much they cost.This is cool and all, but literally 10x over my budget for jacks/stands
I wish there was a clean tidy "correct" way to put all 4 corners on stands for $150, till then I use my judgement and experience to get by. Also my tire installer will rotate for free since I bought the tires there.
Yea. I have been on their list a while. That’s why I ended up going with a quickjack. Sure it’s more money, but everyone seems to love their quickjack.You can check these out. This is what I am considering buying, along with a low clearance floor jack.
They won't eliminate a clearance issue for a too high floor jack, but they do seem to address the issue of being able to jack at the jack points, and then set the car on jack stands. Unfortunately these guys are way behind. I am on their waiting list.
Home
